watchdog: s3c2410_wdt.c: Convert release_resource to release_region/release_mem_region
Request_mem_region should be used with release_mem_region, not
release_resource.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
expression x,E;
*x = request_mem_region(...)
... when != release_mem_region(x)
    when != x = E
* release_resource(x);
Signed-off-by: Julia Lawall
Signed-off-by: Wim Van Sebroeck
Cc: stable
 drivers/watchdog/s3c2410_wdt.c | 19 ++++++++-----------
 1 file changed, 8 insertions(+), 11 deletions(-)
diff --git a/drivers/watchdog/s3c2410_wdt.c b/drivers/watchdog/s3c2410_wdt.c
index 25b39bf..f7f5aa0 100644
--- a/drivers/watchdog/s3c2410_wdt.c
+++ b/drivers/watchdog/s3c2410_wdt.c
@@ -402,7 +402,6 @@ static inline void s3c2410wdt_cpufreq_deregister(void)
 static int __devinit s3c2410wdt_probe(struct platform_device *pdev)
-	struct resource *res;
 	struct device *dev;
 	unsigned int wtcon;
 	int started = 0;
@@ -416,20 +415,19 @@ static int __devinit s3c2410wdt_probe(struct platform_device *pdev)
 	/* get the memory region for the watchdog timer */
-	res = platform_get_resource(pdev, IORESOURCE_MEM, 0);
-	if (res == NULL) {
+	wdt_mem = platform_get_resource(pdev, IORESOURCE_MEM, 0);
+	if (wdt_mem == NULL) {
 		dev_err(dev, "no memory resource specified\n");
 		return -ENOENT;
-	size = resource_size(res);
-	wdt_mem = request_mem_region(res->start, size, pdev->name);
-	if (wdt_mem == NULL) {
+	size = resource_size(wdt_mem);
+	if (!request_mem_region(wdt_mem->start, size, pdev->name)) {
 		dev_err(dev, "failed to get memory region\n");
 		return -EBUSY;
-	wdt_base = ioremap(res->start, size);
+	wdt_base = ioremap(wdt_mem->start, size);
 	if (wdt_base == NULL) {
 		dev_err(dev, "failed to ioremap() region\n");
 		ret = -EINVAL;
@@ -524,8 +522,8 @@ static int __devinit s3c2410wdt_probe(struct platform_device *pdev)
 	iounmap(wdt_base);
  err_req:
-	release_resource(wdt_mem);
-	kfree(wdt_mem);
+	release_mem_region(wdt_mem->start, size);
+	wdt_mem = NULL;
 	return ret;
@@ -545,8 +543,7 @@ static int __devexit s3c2410wdt_remove(struct platform_device *dev)
 	iounmap(wdt_base);
-	kfree(wdt_mem);
+	release_mem_region(wdt_mem->start, resource_size(wdt_mem));
 	wdt_mem = NULL;
 	return 0;
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
