watchdog: pic32-wdt: Remove .owner field for driver
Author: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
Remove .owner field if calls are used which set it automatically.
Generated by: scripts/coccinelle/api/platform_no_drv_owner.cocci
Signed-off-by: Wei Yongjun
Reviewed-by: Guenter Roeck
Signed-off-by: Guenter Roeck
Signed-off-by: Wim Van Sebroeck
 drivers/watchdog/pic32-wdt.c | 1 -
 1 file changed, 1 deletion(-)
diff --git a/drivers/watchdog/pic32-wdt.c b/drivers/watchdog/pic32-wdt.c
index 2b7a2b2..18174fe 100644
--- a/drivers/watchdog/pic32-wdt.c
+++ b/drivers/watchdog/pic32-wdt.c
@@ -251,7 +251,6 @@ static struct platform_driver pic32_wdt_driver = {
 	.remove		= pic32_wdt_drv_remove,
 	.driver		= {
 		.name		= "pic32-wdt",
-		.owner		= THIS_MODULE,
 		.of_match_table = of_match_ptr(pic32_wdt_dt_ids),
BtrLinux
Privacy Overview
