wan: lmc: fix error return code
Author: Julia Lawall <julia.lawall@lip6.fr>
Return a negative error code on failure.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
identifier ret; expression e1,e2;
if (\(ret < 0\|ret != 0\))
 { ... return ret; }
ret = 0
... when != ret = e1
    when != &ret
*if(...)
  ... when != ret = e2
      when forall
 return ret;
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
 drivers/net/wan/lmc/lmc_main.c | 1 +
 1 file changed, 1 insertion(+)
diff --git a/drivers/net/wan/lmc/lmc_main.c b/drivers/net/wan/lmc/lmc_main.c
index bea0f31..317bc79 100644
--- a/drivers/net/wan/lmc/lmc_main.c
+++ b/drivers/net/wan/lmc/lmc_main.c
@@ -850,6 +850,7 @@ static int lmc_init_one(struct pci_dev *pdev, const struct pci_device_id *ent)
 	dev = alloc_hdlcdev(sc);
 	if (!dev) {
 		printk(KERN_ERR "lmc:alloc_netdev for device failed\n");
+		err = -ENOMEM;
 		goto err_hdlcdev;
BtrLinux
Privacy Overview
