wan: dscc4: use msecs_to_jiffies for conversions
Author: Nicholas Mc Guire <hofrat@osadl.org>
API compliance scanning with coccinelle flagged:
./drivers/net/wan/dscc4.c:1036:1-33:
        WARNING: timeout (10) seems HZ dependent
./drivers/net/wan/dscc4.c:554:2-34:
./drivers/net/wan/dscc4.c:599:2-34:
Numeric constants passed to schedule_timeout_*() make the effective
timeout HZ dependent which does not seem to be the intent here.
Fixed up by converting the constant to jiffies with msecs_to_jiffies(),
passing 100ms (assuming HZ==100 in the original code).
Signed-off-by: Nicholas Mc Guire
Signed-off-by: David S. Miller
 drivers/net/wan/dscc4.c | 6 +++---
 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/net/wan/dscc4.c b/drivers/net/wan/dscc4.c
index f76845d..7a72407 100644
--- a/drivers/net/wan/dscc4.c
+++ b/drivers/net/wan/dscc4.c
@@ -551,7 +551,7 @@ static int dscc4_wait_ack_cec(struct dscc4_dev_priv *dpriv,
 			       msg, i);
 			goto done;
-		schedule_timeout_uninterruptible(10);
+		schedule_timeout_uninterruptible(msecs_to_jiffies(100));
 		rmb();
 	} while (++i > 0);
 	netdev_err(dev, "%s timeout\n", msg);
@@ -596,7 +596,7 @@ static inline int dscc4_xpr_ack(struct dscc4_dev_priv *dpriv)
 		    (dpriv->iqtx[cur] & cpu_to_le32(Xpr)))
 			break;
 		smp_rmb();
 	} while (++i > 0);
 	return (i >= 0 ) ? i : -EAGAIN;
@@ -1033,7 +1033,7 @@ static void dscc4_pci_reset(struct pci_dev *pdev, void __iomem *ioaddr)
 	/* Flush posted writes */
 	readl(ioaddr + GSTAR);
 	for (i = 0; i < 16; i++)
 		pci_write_config_dword(pdev, i << 2, dscc4_pci_config_store[i]);
BtrLinux
Privacy Overview
