w1: Use module_pci_driver
Author: Vaishali Thakkar <vthakkar1994@gmail.com>
Use module_pci_driver for drivers whose init and exit functions
only register and unregister, respectively.
A simplified version of the Coccinelle semantic patch that performs
this transformation is as follows:
@a@
identifier f, x;
-static f(...) { return pci_register_driver(&x); }
@b depends on a@
identifier e, a.x;
-static e(...) { pci_unregister_driver(&x); }
@c depends on a && b@
identifier a.f;
declarer name module_init;
-module_init(f);
@d depends on a && b && c@
identifier b.e, a.x;
declarer name module_exit;
declarer name module_pci_driver;
-module_exit(e);
+module_pci_driver(x);
Signed-off-by: Vaishali Thakkar
Acked-by: Evgeniy Polyakov
 drivers/w1/masters/matrox_w1.c | 14 +-------------
 1 file changed, 1 insertion(+), 13 deletions(-)
diff --git a/drivers/w1/masters/matrox_w1.c b/drivers/w1/masters/matrox_w1.c
index d8667b0..684bc9d 100644
--- a/drivers/w1/masters/matrox_w1.c
+++ b/drivers/w1/masters/matrox_w1.c
@@ -232,16 +232,4 @@ static void matrox_w1_remove(struct pci_dev *pdev)
 	kfree(dev);
-static int __init matrox_w1_init(void)
-	return pci_register_driver(&matrox_w1_pci_driver);
-static void __exit matrox_w1_fini(void)
-	pci_unregister_driver(&matrox_w1_pci_driver);
-module_init(matrox_w1_init);
-module_exit(matrox_w1_fini);
+module_pci_driver(matrox_w1_pci_driver);
BtrLinux
Privacy Overview
