video: xilinxfb: replace devm_request_and_ioremap by devm_ioremap_resource
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Use devm_ioremap_resource instead of devm_request_and_ioremap.
This was done using the semantic patch
scripts/coccinelle/api/devm_ioremap_resource.cocci
The initialization of drvdata->regs_phys was manually moved lower, to take
advantage of the NULL test on res performed by devm_ioremap_resource.
Signed-off-by: Julia Lawall
Signed-off-by: Tomi Valkeinen
drivers/video/xilinxfb.c | 8 ++++----
1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/video/xilinxfb.c b/drivers/video/xilinxfb.c
index f3d4a69..236fd42 100644
--- a/drivers/video/xilinxfb.c
+++ b/drivers/video/xilinxfb.c
@@ -259,12 +259,12 @@ static int xilinxfb_assign(struct platform_device *pdev,
struct resource *res;
res = platform_get_resource(pdev, IORESOURCE_MEM, 0);
- drvdata->regs_phys = res->start;
- drvdata->regs = devm_request_and_ioremap(&pdev->dev, res);
- if (!drvdata->regs) {
- rc = -EADDRNOTAVAIL;
+ drvdata->regs = devm_ioremap_resource(&pdev->dev, res);
+ if (IS_ERR(drvdata->regs)) {
+ rc = PTR_ERR(drvdata->regs);
goto err_region;
+ drvdata->regs_phys = res->start;
/* Allocate the framebuffer memory */ |
goto err_region;
