video: udlfb: Deletion of unnecessary checks before the function call “vfree”
Author: Markus Elfring <elfring@users.sourceforge.net>
The vfree() function performs also input parameter validation. Thus the test
around the call is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
Signed-off-by: Tomi Valkeinen
 drivers/video/fbdev/udlfb.c | 9 +++------
 1 file changed, 3 insertions(+), 6 deletions(-)
diff --git a/drivers/video/fbdev/udlfb.c b/drivers/video/fbdev/udlfb.c
index 046d51d..ff2b873 100644
--- a/drivers/video/fbdev/udlfb.c
+++ b/drivers/video/fbdev/udlfb.c
@@ -922,8 +922,7 @@ static void dlfb_free(struct kref *kref)
 	struct dlfb_data *dev = container_of(kref, struct dlfb_data, kref);
-	if (dev->backing_buffer)
-		vfree(dev->backing_buffer);
+	vfree(dev->backing_buffer);
 	kfree(dev->edid);
@@ -953,8 +952,7 @@ static void dlfb_free_framebuffer(struct dlfb_data *dev)
 			fb_dealloc_cmap(&info->cmap);
 		if (info->monspecs.modedb)
 			fb_destroy_modedb(info->monspecs.modedb);
-		if (info->screen_base)
-			vfree(info->screen_base);
+		vfree(info->screen_base);
 		fb_destroy_modelist(&info->modelist);
@@ -1203,8 +1201,7 @@ static int dlfb_realloc_framebuffer(struct dlfb_data *dev, struct fb_info *info)
 		if (!new_back)
 			pr_info("No shadow/backing buffer allocated\n");
 		else {
 			dev->backing_buffer = new_back;
BtrLinux
Privacy Overview
