video: omapdss: delete unneeded of_node_put
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Device node iterators perform an of_node_put on each iteration, so putting
an of_node_put before a continue results in a double put.
A simplified version of the semantic match that finds this problem is as
follows (http://coccinelle.lip6.fr):
expression root,e;
local idexpression child;
iterator i;
 i(..., child, ...) {
   ... when != of_node_get(child)
*  of_node_put(child);
*  continue;
Signed-off-by: Julia Lawall
Signed-off-by: Tomi Valkeinen
 drivers/video/fbdev/omap2/dss/omapdss-boot-init.c | 4 +---
 1 file changed, 1 insertion(+), 3 deletions(-)
diff --git a/drivers/video/fbdev/omap2/dss/omapdss-boot-init.c b/drivers/video/fbdev/omap2/dss/omapdss-boot-init.c
index 8b6f6d5..136d304 100644
--- a/drivers/video/fbdev/omap2/dss/omapdss-boot-init.c
+++ b/drivers/video/fbdev/omap2/dss/omapdss-boot-init.c
@@ -199,10 +199,8 @@ static int __init omapdss_boot_init(void)
 	omapdss_walk_device(dss, true);
 	for_each_available_child_of_node(dss, child) {
-		if (!of_find_property(child, "compatible", NULL)) {
-			of_node_put(child);
+		if (!of_find_property(child, "compatible", NULL))
 			continue;
 		omapdss_walk_device(child, true);
BtrLinux
Privacy Overview
