video: mxsfb: simplify use of devm_ioremap_resource
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Remove unneeded error handling on the result of a call to
platform_get_resource when the value is passed to devm_ioremap_resource.
Move the call to platform_get_resource adjacent to the call to
devm_ioremap_resource to make the connection between them more clear.
A simplified version of the semantic patch that makes this change is as
follows: (http://coccinelle.lip6.fr/)
expression pdev,res,n,e,e1;
expression ret != 0;
identifier l;
- res = platform_get_resource(pdev, IORESOURCE_MEM, n);
... when != res
- if (res == NULL) { ... \(goto l;\|return ret;\) }
... when != res
+ res = platform_get_resource(pdev, IORESOURCE_MEM, n);
e = devm_ioremap_resource(e1, res);
Signed-off-by: Julia Lawall
Signed-off-by: Tomi Valkeinen
drivers/video/mxsfb.c | 7 +------
1 file changed, 1 insertion(+), 6 deletions(-)
diff --git a/drivers/video/mxsfb.c b/drivers/video/mxsfb.c
index 5861ba2..91269f6 100644
--- a/drivers/video/mxsfb.c
+++ b/drivers/video/mxsfb.c
@@ -881,12 +881,6 @@ static int mxsfb_probe(struct platform_device *pdev)
if (of_id)
pdev->id_entry = of_id->data;
- res = platform_get_resource(pdev, IORESOURCE_MEM, 0);
- if (!res) {
- dev_err(&pdev->dev, "Cannot get memory IO resource\n");
- return -ENODEV;
fb_info = framebuffer_alloc(sizeof(struct mxsfb_info), &pdev->dev);
if (!fb_info) {
dev_err(&pdev->dev, "Failed to allocate fbdev\n");
@@ -895,6 +889,7 @@ static int mxsfb_probe(struct platform_device *pdev)
host = to_imxfb_host(fb_info);
+ res = platform_get_resource(pdev, IORESOURCE_MEM, 0);
host->base = devm_ioremap_resource(&pdev->dev, res);
if (IS_ERR(host->base)) {
ret = PTR_ERR(host->base); |
if (of_id)
- if (!res) {
- return -ENODEV;
if (!fb_info) {
