video: msm: Introduce the use of the managed version of kzalloc
Author: Himangi Saraogi <himangi774@gmail.com>
This patch moves data allocated using kzalloc to managed data allocated
using devm_kzalloc and cleans now unnecessary kfrees in probe and remove
functions. Also, linux/device.h is added to make sure the devm_*()
routine declarations are unambiguously available. The function
mddi_dummy_remove is removed as it is no longer required after
removing the kfree. The variable ret is also done away with.
The following Coccinelle semantic patch was used for making a part of
the change:
@platform@
identifier p, probefn, removefn;
struct platform_driver p = {
  .probe = probefn,
  .remove = removefn,
@prb@
identifier platform.probefn, pdev;
expression e, e1, e2;
probefn(struct platform_device *pdev, ...) {
- e = kzalloc(e1, e2)
+ e = devm_kzalloc(&pdev->dev, e1, e2)
?-kfree(e);
@rem depends on prb@
identifier platform.removefn;
expression e;
removefn(...) {
- kfree(e);
Signed-off-by: Himangi Saraogi
Signed-off-by: Tomi Valkeinen
 drivers/video/fbdev/msm/mddi_client_dummy.c | 19 +++----------------
 1 file changed, 3 insertions(+), 16 deletions(-)
diff --git a/drivers/video/fbdev/msm/mddi_client_dummy.c b/drivers/video/fbdev/msm/mddi_client_dummy.c
index f1b0dfc..cdb8f69 100644
--- a/drivers/video/fbdev/msm/mddi_client_dummy.c
+++ b/drivers/video/fbdev/msm/mddi_client_dummy.c
@@ -15,6 +15,7 @@
  * GNU General Public License for more details.
+#include <linux/device.h>
 #include <linux/slab.h>
 #include <linux/module.h>
 #include <linux/kernel.h>
@@ -51,8 +52,7 @@ static int mddi_dummy_probe(struct platform_device *pdev)
 	struct msm_mddi_client_data *client_data = pdev->dev.platform_data;
 	struct panel_info *panel =
-		kzalloc(sizeof(struct panel_info), GFP_KERNEL);
-	int ret;
+		devm_kzalloc(&pdev->dev, sizeof(struct panel_info), GFP_KERNEL);
 	if (!panel)
 		return -ENOMEM;
 	platform_set_drvdata(pdev, panel);
@@ -67,24 +67,11 @@ static int mddi_dummy_probe(struct platform_device *pdev)
 				      client_data->fb_resource, 1);
 	panel->panel_data.fb_data = client_data->private_client_data;
 	panel->pdev.dev.platform_data = &panel->panel_data;
-	ret = platform_device_register(&panel->pdev);
-	if (ret) {
-		kfree(panel);
-		return ret;
-	return 0;
-static int mddi_dummy_remove(struct platform_device *pdev)
-	struct panel_info *panel = platform_get_drvdata(pdev);
-	kfree(panel);
-	return 0;
+	return platform_device_register(&panel->pdev);
 static struct platform_driver mddi_client_dummy = {
 	.probe = mddi_dummy_probe,
-	.remove = mddi_dummy_remove,
 	.driver = { .name = "mddi_c_dummy" },
BtrLinux
Privacy Overview
