video: fbdev: vesafb: use arch_phys_wc_add()
Author: Luis R. Rodriguez <mcgrof@suse.com>
This driver uses the same area for MTRR as for the ioremap_wc(), if
anything it just uses a smaller size in case MTRR reservation fails.
ioremap_wc() API is already used to take advantage of architecture
write-combining when available.
Convert the driver from using the x86 specific MTRR code to
the architecture agnostic arch_phys_wc_add(). arch_phys_wc_add()
will avoid MTRR if write-combining is available.
There are a few motivations for this:
a) Take advantage of PAT when available
b) Help bury MTRR code away, MTRR is architecture specific and on
   x86 its replaced by PAT
c) Help with the goal of eventually using _PAGE_CACHE_UC over
   _PAGE_CACHE_UC_MINUS on x86 on ioremap_nocache() (see commit
   de33c442e titled "x86 PAT: fix performance drop for glx,
   use UC minus for ioremap(), ioremap_nocache() and
   pci_mmap_page_range()")
The conversion done is expressed by the following Coccinelle
SmPL patch, it additionally required manual intervention to
address all the #ifdery and removal of redundant things which
arch_phys_wc_add() already addresses such as verbose message
about when MTRR fails and doing nothing when we didn't get
an MTRR.
@ mtrr_found @
expression index, base, size;
-index = mtrr_add(base, size, MTRR_TYPE_WRCOMB, 1);
+index = arch_phys_wc_add(base, size);
@ mtrr_rm depends on mtrr_found @
expression mtrr_found.index, mtrr_found.base, mtrr_found.size;
-mtrr_del(index, base, size);
+arch_phys_wc_del(index);
@ mtrr_rm_zero_arg depends on mtrr_found @
expression mtrr_found.index;
-mtrr_del(index, 0, 0);
@ mtrr_rm_fb_info depends on mtrr_found @
struct fb_info *info;
-mtrr_del(index, info->fix.smem_start, info->fix.smem_len);
@ ioremap_replace_nocache depends on mtrr_found @
expression base, size;
-info->screen_base = ioremap_nocache(base, size);
+info->screen_base = ioremap_wc(base, size);
@ ioremap_replace_default depends on mtrr_found @
-info->screen_base = ioremap(base, size);
Generated-by: Coccinelle SmPL
Cc: Toshi Kani
Cc: Suresh Siddha
Cc: Ingo Molnar
Cc: Thomas Gleixner
Cc: Juergen Gross
Cc: Daniel Vetter
Cc: Andy Lutomirski
Cc: Dave Airlie
Cc: Antonino Daplas
Cc: Jean-Christophe Plagniol-Villard
Cc: Rob Clark
Cc: Jingoo Han
Cc: Wolfram Sang
Cc: Tomi Valkeinen
Cc: linux-fbdev@vger.kernel.org
Cc: linux-kernel@vger.kernel.org
Signed-off-by: Luis R. Rodriguez
Signed-off-by: Tomi Valkeinen
 drivers/video/fbdev/vesafb.c | 29 ++++++++---------------------
 1 file changed, 8 insertions(+), 21 deletions(-)
diff --git a/drivers/video/fbdev/vesafb.c b/drivers/video/fbdev/vesafb.c
index 3db3908..528fe91 100644
--- a/drivers/video/fbdev/vesafb.c
+++ b/drivers/video/fbdev/vesafb.c
@@ -19,10 +19,9 @@
 #include <linux/init.h>
 #include <linux/platform_device.h>
 #include <linux/screen_info.h>
+#include <linux/io.h>
 #include <video/vga.h>
-#include <asm/io.h>
-#include <asm/mtrr.h>
 #define dac_reg	(0x3c8)
 #define dac_val	(0x3c9)
@@ -180,16 +179,10 @@ static int vesafb_setcolreg(unsigned regno, unsigned red, unsigned green,
 static void vesafb_destroy(struct fb_info *info)
-#ifdef CONFIG_MTRR
 	struct vesafb_par *par = info->par;
-#endif
 	fb_dealloc_cmap(&info->cmap);
-#ifdef CONFIG_MTRR
-	if (par->wc_cookie >= 0)
-		mtrr_del(par->wc_cookie, 0, 0);
-#endif
+	arch_phys_wc_del(par->wc_cookie);
 	if (info->screen_base)
 		iounmap(info->screen_base);
 	release_mem_region(info->apertures->ranges[0].base, info->apertures->ranges[0].size);
@@ -420,7 +413,6 @@ static int vesafb_probe(struct platform_device *dev)
 	request_region(0x3c0, 32, "vesafb");
 	if (mtrr == 3) {
-#ifdef CONFIG_MTRR
 		unsigned int temp_size = size_total;
 		/* Find the largest power-of-two */
@@ -428,18 +420,16 @@ static int vesafb_probe(struct platform_device *dev)
 		/* Try and find a power of two to add */
 		do {
-			par->wc_cookie = mtrr_add(vesafb_fix.smem_start,
-						  temp_size,
-						  MTRR_TYPE_WRCOMB, 1);
+			par->wc_cookie =
+				arch_phys_wc_add(vesafb_fix.smem_start,
+						 temp_size);
 			temp_size >>= 1;
-		} while (temp_size >= PAGE_SIZE && par->wc_cookie == -EINVAL);
-#endif
+		} while (temp_size >= PAGE_SIZE && par->wc_cookie < 0);
 		info->screen_base = ioremap_wc(vesafb_fix.smem_start, vesafb_fix.smem_len);
 	} else {
-#ifdef CONFIG_MTRR
 		if (mtrr && mtrr != 3)
 			WARN_ONCE(1, "Only MTRR_TYPE_WRCOMB (3) make sense\n");
-#endif
 		info->screen_base = ioremap(vesafb_fix.smem_start, vesafb_fix.smem_len);
@@ -477,10 +467,7 @@ static int vesafb_probe(struct platform_device *dev)
 	fb_info(info, "%s frame buffer device\n", info->fix.id);
 	return 0;
 err:
-#ifdef CONFIG_MTRR
-#endif
 	framebuffer_release(info);
BtrLinux
Privacy Overview
