video: fbdev: tdfxfb: use arch_phys_wc_add() and ioremap_wc()
Author: Luis R. Rodriguez <mcgrof@suse.com>
This driver uses the same area for MTRR as for the ioremap().
Convert the driver from using the x86 specific MTRR code to
the architecture agnostic arch_phys_wc_add(). arch_phys_wc_add()
will avoid MTRR if write-combining is available, in order to
take advantage of that also ensure the ioremap'd area is requested
as write-combining.
There are a few motivations for this:
a) Take advantage of PAT when available
b) Help bury MTRR code away, MTRR is architecture specific and on
   x86 its replaced by PAT
c) Help with the goal of eventually using _PAGE_CACHE_UC over
   _PAGE_CACHE_UC_MINUS on x86 on ioremap_nocache() (see commit
   de33c442e titled "x86 PAT: fix performance drop for glx,
   use UC minus for ioremap(), ioremap_nocache() and
   pci_mmap_page_range()")
The conversion done is expressed by the following Coccinelle
SmPL patch, it additionally required manual intervention to
address all the #ifdery and removal of redundant things which
arch_phys_wc_add() already addresses such as verbose message
about when MTRR fails and doing nothing when we didn't get
an MTRR.
@ mtrr_found @
expression index, base, size;
-index = mtrr_add(base, size, MTRR_TYPE_WRCOMB, 1);
+index = arch_phys_wc_add(base, size);
@ mtrr_rm depends on mtrr_found @
expression mtrr_found.index, mtrr_found.base, mtrr_found.size;
-mtrr_del(index, base, size);
+arch_phys_wc_del(index);
@ mtrr_rm_zero_arg depends on mtrr_found @
expression mtrr_found.index;
-mtrr_del(index, 0, 0);
@ mtrr_rm_fb_info depends on mtrr_found @
struct fb_info *info;
-mtrr_del(index, info->fix.smem_start, info->fix.smem_len);
@ ioremap_replace_nocache depends on mtrr_found @
expression base, size;
-info->screen_base = ioremap_nocache(base, size);
+info->screen_base = ioremap_wc(base, size);
@ ioremap_replace_default depends on mtrr_found @
-info->screen_base = ioremap(base, size);
Generated-by: Coccinelle SmPL
Cc: Rob Clark
Cc: Geert Uytterhoeven
Cc: Suresh Siddha
Cc: Ingo Molnar
Cc: Thomas Gleixner
Cc: Juergen Gross
Cc: Daniel Vetter
Cc: Andy Lutomirski
Cc: Dave Airlie
Cc: Antonino Daplas
Cc: Jean-Christophe Plagniol-Villard
Cc: Tomi Valkeinen
Cc: linux-fbdev@vger.kernel.org
Cc: linux-kernel@vger.kernel.org
Signed-off-by: Luis R. Rodriguez
Reviewed-by: Dave Airlie
Signed-off-by: Tomi Valkeinen
 drivers/video/fbdev/tdfxfb.c | 41 ++++++-----------------------------------
 include/video/tdfx.h         |  2 +-
 2 files changed, 7 insertions(+), 36 deletions(-)
diff --git a/drivers/video/fbdev/tdfxfb.c b/drivers/video/fbdev/tdfxfb.c
index f761fe3..621fa44 100644
--- a/drivers/video/fbdev/tdfxfb.c
+++ b/drivers/video/fbdev/tdfxfb.c
@@ -78,24 +78,6 @@
 #define DPRINTK(a, b...) pr_debug("fb: %s: " a, __func__ , ## b)
-#ifdef CONFIG_MTRR
-#include <asm/mtrr.h>
-#else
-/* duplicate asm/mtrr.h defines to work on archs without mtrr */
-#define MTRR_TYPE_WRCOMB     1
-static inline int mtrr_add(unsigned long base, unsigned long size,
-				unsigned int type, char increment)
-    return -ENODEV;
-static inline int mtrr_del(int reg, unsigned long base,
-				unsigned long size)
-    return -ENODEV;
-#endif
 #define BANSHEE_MAX_PIXCLOCK 270000
 #define VOODOO3_MAX_PIXCLOCK 300000
 #define VOODOO5_MAX_PIXCLOCK 350000
@@ -167,7 +149,6 @@ static int nopan;
 static int nowrap = 1;      /* not implemented (yet) */
 static int hwcursor = 1;
 static char *mode_option;
-/* mtrr option */
 static bool nomtrr;
@@ -1454,8 +1435,8 @@ static int tdfxfb_probe(struct pci_dev *pdev, const struct pci_device_id *id)
 		goto out_err_regbase;
-	info->screen_base = ioremap_nocache(info->fix.smem_start,
-					    info->fix.smem_len);
+	info->screen_base = ioremap_wc(info->fix.smem_start,
+				       info->fix.smem_len);
 	if (!info->screen_base) {
 		printk(KERN_ERR "fb: Can't remap %s framebuffer.\n",
 				info->fix.id);
@@ -1473,11 +1454,9 @@ static int tdfxfb_probe(struct pci_dev *pdev, const struct pci_device_id *id)
 	printk(KERN_INFO "fb: %s memory = %dK\n", info->fix.id,
 			info->fix.smem_len >> 10);
-	default_par->mtrr_handle = -1;
 	if (!nomtrr)
-			mtrr_add(info->fix.smem_start, info->fix.smem_len,
-				 MTRR_TYPE_WRCOMB, 1);
+		default_par->wc_cookie= arch_phys_wc_add(info->fix.smem_start,
 	info->fix.ypanstep	= nopan ? 0 : 1;
 	info->fix.ywrapstep	= nowrap ? 0 : 1;
@@ -1566,9 +1545,7 @@ out_err_iobase:
 #ifdef CONFIG_FB_3DFX_I2C
 	tdfxfb_delete_i2c_busses(default_par);
 #endif
-	if (default_par->mtrr_handle >= 0)
-		mtrr_del(default_par->mtrr_handle, info->fix.smem_start,
+	arch_phys_wc_del(default_par->wc_cookie);
 	release_region(pci_resource_start(pdev, 2),
 		       pci_resource_len(pdev, 2));
 out_err_screenbase:
@@ -1604,10 +1581,8 @@ static void __init tdfxfb_setup(char *options)
 			nowrap = 1;
 		} else if (!strncmp(this_opt, "hwcursor=", 9)) {
 			hwcursor = simple_strtoul(this_opt + 9, NULL, 0);
-#ifdef CONFIG_MTRR
 		} else if (!strncmp(this_opt, "nomtrr", 6)) {
 			nomtrr = 1;
-#endif
 		} else {
 			mode_option = this_opt;
@@ -1633,9 +1608,7 @@ static void tdfxfb_remove(struct pci_dev *pdev)
 	tdfxfb_delete_i2c_busses(par);
 #endif
-	if (par->mtrr_handle >= 0)
-		mtrr_del(par->mtrr_handle, info->fix.smem_start,
+	arch_phys_wc_del(par->wc_cookie);
 	iounmap(par->regbase_virt);
 	iounmap(info->screen_base);
@@ -1677,10 +1650,8 @@ MODULE_PARM_DESC(hwcursor, "Enable hardware cursor "
 			"(1=enable, 0=disable, default=1)");
 module_param(mode_option, charp, 0);
 MODULE_PARM_DESC(mode_option, "Initial video mode e.g. '648x480-8@60'");
-#ifdef CONFIG_MTRR
 module_param(nomtrr, bool, 0);
 MODULE_PARM_DESC(nomtrr, "Disable MTRR support (default: enabled)");
-#endif
 module_init(tdfxfb_init);
 module_exit(tdfxfb_exit);
diff --git a/include/video/tdfx.h b/include/video/tdfx.h
index befbaf0..69674b9 100644
--- a/include/video/tdfx.h
+++ b/include/video/tdfx.h
@@ -196,7 +196,7 @@ struct tdfx_par {
 	u32 palette[16];
 	void __iomem *regbase_virt;
 	unsigned long iobase;
-	int mtrr_handle;
+	int wc_cookie;
 	struct tdfxfb_i2c_chan chan[2];
 #endif
BtrLinux
Privacy Overview
