video: fbdev-SIS: Deletion of unnecessary checks before the function call “pci_dev_put”
Author: Markus Elfring <elfring@users.sourceforge.net>
The pci_dev_put() function tests whether its argument is NULL
and then returns immediately. Thus the test around the call
is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
Signed-off-by: Tomi Valkeinen
 drivers/video/fbdev/sis/sis_main.c | 14 +++++---------
 1 file changed, 5 insertions(+), 9 deletions(-)
diff --git a/drivers/video/fbdev/sis/sis_main.c b/drivers/video/fbdev/sis/sis_main.c
index e5d11b1..fcf610e 100644
--- a/drivers/video/fbdev/sis/sis_main.c
+++ b/drivers/video/fbdev/sis/sis_main.c
@@ -5989,7 +5989,7 @@ static int sisfb_probe(struct pci_dev *pdev, const struct pci_device_id *ent)
 	if(!ivideo->sisvga_enabled) {
 		if(pci_enable_device(pdev)) {
-			if(ivideo->nbridge) pci_dev_put(ivideo->nbridge);
+			pci_dev_put(ivideo->nbridge);
 			framebuffer_release(sis_fb_info);
 			return -EIO;
@@ -6202,10 +6202,8 @@ error_0:	iounmap(ivideo->video_vbase);
 error_1:	release_mem_region(ivideo->video_base, ivideo->video_size);
 error_2:	release_mem_region(ivideo->mmio_base, ivideo->mmio_size);
 error_3:	vfree(ivideo->bios_abase);
-		if(ivideo->lpcdev)
-			pci_dev_put(ivideo->lpcdev);
-			pci_dev_put(ivideo->nbridge);
+		pci_dev_put(ivideo->lpcdev);
 			pci_disable_device(pdev);
@@ -6505,11 +6503,9 @@ static void sisfb_remove(struct pci_dev *pdev)
 #ifdef CONFIG_MTRR
 	/* Release MTRR region */
BtrLinux
Privacy Overview
