drivers/video/fbdev/aty/radeon_base.c | 29 ++++++-----------------------
drivers/video/fbdev/aty/radeonfb.h | 2 +-
2 files changed, 7 insertions(+), 24 deletions(-)
diff --git a/drivers/video/fbdev/aty/radeon_base.c b/drivers/video/fbdev/aty/radeon_base.c
index 01237c8..2bdb070 100644
--- a/drivers/video/fbdev/aty/radeon_base.c
+++ b/drivers/video/fbdev/aty/radeon_base.c
@@ -85,10 +85,6 @@
#endif /* CONFIG_PPC */
-#ifdef CONFIG_MTRR
-#include <asm/mtrr.h>
-#endif
#include <video/radeon.h>
#include <linux/radeonfb.h>
@@ -271,9 +267,7 @@ static bool mirror = 0;
static int panel_yres = 0;
static bool force_dfp = 0;
static bool force_measure_pll = 0;
-#ifdef CONFIG_MTRR
static bool nomtrr = 0;
-#endif
static bool force_sleep;
static bool ignore_devlist;
#ifdef CONFIG_PMAC_BACKLIGHT
@@ -2260,8 +2254,8 @@ static int radeonfb_pci_register(struct pci_dev *pdev,
rinfo->mapped_vram = min_t(unsigned long, MAX_MAPPED_VRAM, rinfo->video_ram);
do {
- rinfo->fb_base = ioremap (rinfo->fb_base_phys,
- rinfo->mapped_vram);
+ rinfo->fb_base = ioremap_wc(rinfo->fb_base_phys,
+ rinfo->mapped_vram);
} while (rinfo->fb_base == NULL &&
((rinfo->mapped_vram /= 2) >= MIN_MAPPED_VRAM));
@@ -2359,11 +2353,9 @@ static int radeonfb_pci_register(struct pci_dev *pdev,
goto err_unmap_fb;
-#ifdef CONFIG_MTRR
- rinfo->mtrr_hdl = nomtrr ? -1 : mtrr_add(rinfo->fb_base_phys,
- rinfo->video_ram,
- MTRR_TYPE_WRCOMB, 1);
-#endif
+ if (!nomtrr)
+ rinfo->wc_cookie = arch_phys_wc_add(rinfo->fb_base_phys,
+ rinfo->video_ram);
if (backlight)
radeonfb_bl_init(rinfo);
@@ -2428,12 +2420,7 @@ static void radeonfb_pci_unregister(struct pci_dev *pdev)
#endif
del_timer_sync(&rinfo->lvds_timer);
-#ifdef CONFIG_MTRR
- if (rinfo->mtrr_hdl >= 0)
- mtrr_del(rinfo->mtrr_hdl, 0, 0);
-#endif
+ arch_phys_wc_del(rinfo->wc_cookie);
unregister_framebuffer(info);
radeonfb_bl_exit(rinfo);
@@ -2489,10 +2476,8 @@ static int __init radeonfb_setup (char *options)
panel_yres = simple_strtoul((this_opt+11), NULL, 0);
} else if (!strncmp(this_opt, "backlight:", 10)) {
backlight = simple_strtoul(this_opt+10, NULL, 0);
-#ifdef CONFIG_MTRR
} else if (!strncmp(this_opt, "nomtrr", 6)) {
nomtrr = 1;
-#endif
} else if (!strncmp(this_opt, "nomodeset", 9)) {
nomodeset = 1;
} else if (!strncmp(this_opt, "force_measure_pll", 17)) {
@@ -2552,10 +2537,8 @@ module_param(monitor_layout, charp, 0);
MODULE_PARM_DESC(monitor_layout, "Specify monitor mapping (like XFree86)");
module_param(force_measure_pll, bool, 0);
MODULE_PARM_DESC(force_measure_pll, "Force measurement of PLL (debug)");
-#ifdef CONFIG_MTRR
module_param(nomtrr, bool, 0);
MODULE_PARM_DESC(nomtrr, "bool: disable use of MTRR registers");
-#endif
module_param(panel_yres, int, 0);
MODULE_PARM_DESC(panel_yres, "int: set panel yres");
module_param(mode_option, charp, 0);
diff --git a/drivers/video/fbdev/aty/radeonfb.h b/drivers/video/fbdev/aty/radeonfb.h
index 039def4..5bc1944 100644
--- a/drivers/video/fbdev/aty/radeonfb.h
+++ b/drivers/video/fbdev/aty/radeonfb.h
@@ -340,7 +340,7 @@ struct radeonfb_info {
struct pll_info pll;
- int mtrr_hdl;
+ int wc_cookie;
u32 save_regs[100];
int asleep; |
