drivers/video/fbdev/matrox/matroxfb_base.c | 36 +++++++++++-------------------
drivers/video/fbdev/matrox/matroxfb_base.h | 27 +---------------------
2 files changed, 14 insertions(+), 49 deletions(-)
diff --git a/drivers/video/fbdev/matrox/matroxfb_base.c b/drivers/video/fbdev/matrox/matroxfb_base.c
index 2ba4e54..11eb094 100644
--- a/drivers/video/fbdev/matrox/matroxfb_base.c
+++ b/drivers/video/fbdev/matrox/matroxfb_base.c
@@ -370,12 +370,9 @@ static void matroxfb_remove(struct matrox_fb_info *minfo, int dummy)
matroxfb_unregister_device(minfo);
unregister_framebuffer(&minfo->fbcon);
matroxfb_g450_shutdown(minfo);
-#ifdef CONFIG_MTRR
- if (minfo->mtrr.vram_valid)
- mtrr_del(minfo->mtrr.vram, minfo->video.base, minfo->video.len);
-#endif
- mga_iounmap(minfo->mmio.vbase);
- mga_iounmap(minfo->video.vbase);
+ arch_phys_wc_del(minfo->wc_cookie);
+ iounmap(minfo->mmio.vbase.vaddr);
+ iounmap(minfo->video.vbase.vaddr);
release_mem_region(minfo->video.base, minfo->video.len_maximum);
release_mem_region(minfo->mmio.base, 16384);
kfree(minfo);
@@ -1252,9 +1249,7 @@ static int nobios; /* "matroxfb:nobios" */
static int noinit = 1; /* "matroxfb:init" */
static int inverse; /* "matroxfb:inverse" */
static int sgram; /* "matroxfb:sgram" */
-#ifdef CONFIG_MTRR
static int mtrr = 1; /* "matroxfb:nomtrr" */
-#endif
static int grayscale; /* "matroxfb:grayscale" */
static int dev = -1; /* "matroxfb:dev:xxxxx" */
static unsigned int vesa = ~0; /* "matroxfb:vesa:xxxxx" */
@@ -1713,14 +1708,17 @@ static int initMatrox2(struct matrox_fb_info *minfo, struct board *b)
if (mem && (mem < memsize))
memsize = mem;
err = -ENOMEM;
- if (mga_ioremap(ctrlptr_phys, 16384, MGA_IOREMAP_MMIO, &minfo->mmio.vbase)) {
+ minfo->mmio.vbase.vaddr = ioremap_nocache(ctrlptr_phys, 16384);
+ if (!minfo->mmio.vbase.vaddr) {
printk(KERN_ERR "matroxfb: cannot ioremap(%lX, 16384), matroxfb disabled\n", ctrlptr_phys);
goto failVideoMR;
minfo->mmio.base = ctrlptr_phys;
minfo->mmio.len = 16384;
minfo->video.base = video_base_phys;
- if (mga_ioremap(video_base_phys, memsize, MGA_IOREMAP_FB, &minfo->video.vbase)) {
+ minfo->video.vbase.vaddr = ioremap_wc(video_base_phys, memsize);
+ if (!minfo->video.vbase.vaddr) {
printk(KERN_ERR "matroxfb: cannot ioremap(%lX, %d), matroxfb disabled\n",
goto failCtrlIO;
@@ -1768,13 +1766,9 @@ static int initMatrox2(struct matrox_fb_info *minfo, struct board *b)
minfo->video.len_usable = minfo->video.len;
if (minfo->video.len_usable > b->base->maxdisplayable)
minfo->video.len_usable = b->base->maxdisplayable;
-#ifdef CONFIG_MTRR
- if (mtrr) {
- minfo->mtrr.vram = mtrr_add(video_base_phys, minfo->video.len, MTRR_TYPE_WRCOMB, 1);
- minfo->mtrr.vram_valid = 1;
- printk(KERN_INFO "matroxfb: MTRR's turned on\n");
-#endif /* CONFIG_MTRR */
+ if (mtrr)
+ minfo->wc_cookie = arch_phys_wc_add(video_base_phys,
+ minfo->video.len);
if (!minfo->devflags.novga)
request_region(0x3C0, 32, "matrox");
@@ -1943,9 +1937,9 @@ static int initMatrox2(struct matrox_fb_info *minfo, struct board *b)
return 0;
failVideoIO:;
failCtrlIO:;
failVideoMR:;
release_mem_region(video_base_phys, minfo->video.len_maximum);
failCtrlMR:;
@@ -2439,10 +2433,8 @@ static int __init matroxfb_setup(char *options) {
nobios = !value;
else if (!strcmp(this_opt, "init"))
noinit = !value;
-#ifdef CONFIG_MTRR
else if (!strcmp(this_opt, "mtrr"))
mtrr = value;
-#endif
else if (!strcmp(this_opt, "inv24"))
inv24 = value;
else if (!strcmp(this_opt, "cross4MB"))
@@ -2511,10 +2503,8 @@ module_param(noinit, int, 0);
MODULE_PARM_DESC(noinit, "Disables W/SG/SD-RAM and bus interface initialization (0 or 1=do not initialize) (default=0)");
module_param(memtype, int, 0);
MODULE_PARM_DESC(memtype, "Memory type for G200/G400 (see Documentation/fb/matroxfb.txt for explanation) (default=3 for G200, 0 for G400)");
-#ifdef CONFIG_MTRR
module_param(mtrr, int, 0);
MODULE_PARM_DESC(mtrr, "This speeds up video memory accesses (0=disabled or 1) (default=1)");
-#endif
module_param(sgram, int, 0);
MODULE_PARM_DESC(sgram, "Indicates that G100/G200/G400 has SGRAM memory (0=SDRAM, 1=SGRAM) (default=0)");
module_param(inv24, int, 0);
diff --git a/drivers/video/fbdev/matrox/matroxfb_base.h b/drivers/video/fbdev/matrox/matroxfb_base.h
index 89a8a89a..09b02cd 100644
--- a/drivers/video/fbdev/matrox/matroxfb_base.h
+++ b/drivers/video/fbdev/matrox/matroxfb_base.h
@@ -44,9 +44,6 @@
#include <asm/io.h>
#include <asm/unaligned.h>
-#ifdef CONFIG_MTRR
-#include <asm/mtrr.h>
-#endif
#if defined(CONFIG_PPC_PMAC)
#include <asm/prom.h>
@@ -187,23 +184,6 @@ static inline void __iomem* vaddr_va(vaddr_t va) {
return va.vaddr;
-#define MGA_IOREMAP_NORMAL 0
-#define MGA_IOREMAP_NOCACHE 1
-#define MGA_IOREMAP_FB MGA_IOREMAP_NOCACHE
-#define MGA_IOREMAP_MMIO MGA_IOREMAP_NOCACHE
-static inline int mga_ioremap(unsigned long phys, unsigned long size, int flags, vaddr_t* virt) {
- if (flags & MGA_IOREMAP_NOCACHE)
- virt->vaddr = ioremap_nocache(phys, size);
- else
- virt->vaddr = ioremap(phys, size);
- return (virt->vaddr == NULL); /* 0, !0... 0, error_code in future */
-static inline void mga_iounmap(vaddr_t va) {
- iounmap(va.vaddr);
struct my_timming {
unsigned int pixclock;
int mnp;
@@ -449,12 +429,7 @@ struct matrox_fb_info {
int plnwt;
int srcorg;
} capable;
-#ifdef CONFIG_MTRR
- struct {
- int vram;
- int vram_valid;
- } mtrr;
-#endif
+ int wc_cookie;
struct {
int precise_width;
int mga_24bpp_fix; |
