V4L/DVB: drivers/video/omap2/displays: add missing mutex_unlock
Add a mutex_unlock missing on the error paths.  The use of the mutex is
balanced elsewhere in the file.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
expression E1;
* mutex_lock(E1,...);
  <+... when != E1
  if (...) {
    ... when != E1
*   return ...;
* mutex_unlock(E1,...);
Signed-off-by: Julia Lawall
Acked-by: Mike Isely
Signed-off-by: Andrew Morton
Signed-off-by: Mauro Carvalho Chehab
 drivers/video/omap2/displays/panel-acx565akm.c | 4 +++-
 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/drivers/video/omap2/displays/panel-acx565akm.c b/drivers/video/omap2/displays/panel-acx565akm.c
index 1f8eb70..07fbb8a 100644
--- a/drivers/video/omap2/displays/panel-acx565akm.c
+++ b/drivers/video/omap2/displays/panel-acx565akm.c
@@ -592,7 +592,7 @@ static int acx_panel_power_on(struct omap_dss_device *dssdev)
 	r = omapdss_sdi_display_enable(dssdev);
 	if (r) {
 		pr_err("%s sdi enable failed\n", __func__);
-		return r;
+		goto fail_unlock;
 	/*FIXME tweak me */
@@ -633,6 +633,8 @@ static int acx_panel_power_on(struct omap_dss_device *dssdev)
 	return acx565akm_bl_update_status(md->bl_dev);
 fail:
 	omapdss_sdi_display_disable(dssdev);
+fail_unlock:
+	mutex_unlock(&md->mutex);
 	return r;
BtrLinux
Privacy Overview
