V4L/DVB: drivers/media/video/pvrusb2: Add missing mutex_unlock
Add a mutex_unlock missing on the error path.  In the other functions in
the same file the locks and unlocks of this mutex appear to be balanced,
so it would seem that the same should hold in this case.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
expression E1;
* mutex_lock(E1,...);
  <+... when != E1
  if (...) {
    ... when != E1
*   return ...;
* mutex_unlock(E1,...);
Signed-off-by: Julia Lawall
Signed-off-by: Douglas Schilling Landgraf
Signed-off-by: Mauro Carvalho Chehab
 drivers/media/video/pvrusb2/pvrusb2-ioread.c | 5 ++++-
 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/drivers/media/video/pvrusb2/pvrusb2-ioread.c b/drivers/media/video/pvrusb2/pvrusb2-ioread.c
index b482478..bba6115 100644
--- a/drivers/media/video/pvrusb2/pvrusb2-ioread.c
+++ b/drivers/media/video/pvrusb2/pvrusb2-ioread.c
@@ -223,7 +223,10 @@ int pvr2_ioread_setup(struct pvr2_ioread *cp,struct pvr2_stream *sp)
 				   " pvr2_ioread_setup (setup) id=%p",cp);
 			pvr2_stream_kill(sp);
 			ret = pvr2_stream_set_buffer_count(sp,BUFFER_COUNT);
-			if (ret < 0) return ret;
+			if (ret < 0) {
+				mutex_unlock(&cp->mutex);
+				return ret;
 			for (idx = 0; idx < BUFFER_COUNT; idx++) {
 				bp = pvr2_stream_get_buffer(sp,idx);
 				pvr2_buffer_set_buffer(bp,
BtrLinux
Privacy Overview
