V4L/DVB: drivers/media: Use memdup_user
Use memdup_user when user data is immediately copied into the
allocated region.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
expression from,to,size,flag;
position p;
identifier l1,l2;
-  to = \(kmalloc@p\|kzalloc@p\)(size,flag);
+  to = memdup_user(from,size);
   if (
-      to==NULL
+      IS_ERR(to)
   <+... when != goto l1;
-  -ENOMEM
+  PTR_ERR(to)
-  if (copy_from_user(to, from, size) != 0) {
-    <+... when != goto l2;
-    -EFAULT
Signed-off-by: Julia Lawall
Signed-off-by: Mauro Carvalho Chehab
 drivers/media/dvb/dvb-core/dvb_demux.c | 10 +++-------
 drivers/media/video/dabusb.c           | 13 ++++---------
 2 files changed, 7 insertions(+), 16 deletions(-)
diff --git a/drivers/media/dvb/dvb-core/dvb_demux.c b/drivers/media/dvb/dvb-core/dvb_demux.c
index 977ddba..4a88a3e 100644
--- a/drivers/media/dvb/dvb-core/dvb_demux.c
+++ b/drivers/media/dvb/dvb-core/dvb_demux.c
@@ -1130,13 +1130,9 @@ static int dvbdmx_write(struct dmx_demux *demux, const char __user *buf, size_t
 	if ((!demux->frontend) || (demux->frontend->source != DMX_MEMORY_FE))
 		return -EINVAL;
-	p = kmalloc(count, GFP_USER);
-	if (!p)
-		return -ENOMEM;
-	if (copy_from_user(p, buf, count)) {
-		kfree(p);
-		return -EFAULT;
+	p = memdup_user(buf, count);
+	if (IS_ERR(p))
+		return PTR_ERR(p);
 	if (mutex_lock_interruptible(&dvbdemux->mutex)) {
 		kfree(p);
 		return -ERESTARTSYS;
diff --git a/drivers/media/video/dabusb.c b/drivers/media/video/dabusb.c
index 0f50508..5b176bd 100644
--- a/drivers/media/video/dabusb.c
+++ b/drivers/media/video/dabusb.c
@@ -706,16 +706,11 @@ static long dabusb_ioctl (struct file *file, unsigned int cmd, unsigned long arg
 	switch (cmd) {
 	case IOCTL_DAB_BULK:
-		pbulk = kmalloc(sizeof (bulk_transfer_t), GFP_KERNEL);
+		pbulk = memdup_user((void __user *)arg,
+				    sizeof(bulk_transfer_t));
-		if (!pbulk) {
-			ret = -ENOMEM;
-			break;
-		if (copy_from_user (pbulk, (void __user *) arg, sizeof (bulk_transfer_t))) {
-			ret = -EFAULT;
-			kfree (pbulk);
+		if (IS_ERR(pbulk)) {
+			ret = PTR_ERR(pbulk);
 			break;
BtrLinux
Privacy Overview
