V4L/DVB (9638): drivers/media: use ARRAY_SIZE
ARRAY_SIZE is more concise to use when the size of an array is divided by
the size of its type or the size of its first element.
The semantic patch that makes this change is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@i@
@depends on i using "paren.iso"@
type T;
T[] E;
- (sizeof(E)/sizeof(E[...]))
+ ARRAY_SIZE(E)
type T;
T[] E;
- (sizeof(E)/sizeof(T))
+ ARRAY_SIZE(E)
Signed-off-by: Julia Lawall
Signed-off-by: Andrew Morton
Signed-off-by: Mauro Carvalho Chehab
 drivers/media/common/tuners/mxl5005s.c        | 6 +++---
 drivers/media/video/gspca/gspca.c             | 2 +-
 drivers/media/video/gspca/mars.c              | 2 +-
 drivers/media/video/gspca/spca500.c           | 4 ++--
 drivers/media/video/saa7134/saa7134-tvaudio.c | 2 +-
 5 files changed, 8 insertions(+), 8 deletions(-)
diff --git a/drivers/media/common/tuners/mxl5005s.c b/drivers/media/common/tuners/mxl5005s.c
index a887824..31522d2 100644
--- a/drivers/media/common/tuners/mxl5005s.c
+++ b/drivers/media/common/tuners/mxl5005s.c
@@ -3598,7 +3598,7 @@ static u16 MXL_GetInitRegister(struct dvb_frontend *fe, u8 *RegNum,
 		76, 77, 91, 134, 135, 137, 147,
 		156, 166, 167, 168, 25 };
-	*count = sizeof(RegAddr) / sizeof(u8);
+	*count = ARRAY_SIZE(RegAddr);
 	status += MXL_BlockInit(fe);
@@ -3630,7 +3630,7 @@ static u16 MXL_GetCHRegister(struct dvb_frontend *fe, u8 *RegNum, u8 *RegVal,
 #endif
 	for (i = 0 ; i < *count; i++) {
 		RegNum[i] = RegAddr[i];
@@ -3648,7 +3648,7 @@ static u16 MXL_GetCHRegister_ZeroIF(struct dvb_frontend *fe, u8 *RegNum,
 	u8 RegAddr[] = {43, 136};
 	for (i = 0; i < *count; i++) {
diff --git a/drivers/media/video/gspca/gspca.c b/drivers/media/video/gspca/gspca.c
index 78a2214..02d6a48 100644
--- a/drivers/media/video/gspca/gspca.c
+++ b/drivers/media/video/gspca/gspca.c
@@ -736,7 +736,7 @@ static int vidioc_enum_fmt_vid_cap(struct file *file, void  *priv,
 			if (fmtdesc->index == index)
 				break;		/* new format */
 			index++;
-			if (index >= sizeof fmt_tb / sizeof fmt_tb[0])
+			if (index >= ARRAY_SIZE(fmt_tb))
 				return -EINVAL;
diff --git a/drivers/media/video/gspca/mars.c b/drivers/media/video/gspca/mars.c
index 277ca34..492cdd3 100644
--- a/drivers/media/video/gspca/mars.c
+++ b/drivers/media/video/gspca/mars.c
@@ -123,7 +123,7 @@ static int sd_config(struct gspca_dev *gspca_dev,
 	cam = &gspca_dev->cam;
 	cam->epaddr = 0x01;
 	cam->cam_mode = vga_mode;
-	cam->nmodes = sizeof vga_mode / sizeof vga_mode[0];
+	cam->nmodes = ARRAY_SIZE(vga_mode);
 	sd->qindex = 1;			/* set the quantization table */
 	return 0;
diff --git a/drivers/media/video/gspca/spca500.c b/drivers/media/video/gspca/spca500.c
index bca106c..09ff697 100644
--- a/drivers/media/video/gspca/spca500.c
+++ b/drivers/media/video/gspca/spca500.c
@@ -633,10 +633,10 @@ static int sd_config(struct gspca_dev *gspca_dev,
 	sd->subtype = id->driver_info;
 	if (sd->subtype != LogitechClickSmart310) {
 	} else {
 		cam->cam_mode = sif_mode;
-		cam->nmodes = sizeof sif_mode / sizeof sif_mode[0];
+		cam->nmodes = ARRAY_SIZE(sif_mode);
 	sd->qindex = 5;
 	sd->brightness = BRIGHTNESS_DEF;
diff --git a/drivers/media/video/saa7134/saa7134-tvaudio.c b/drivers/media/video/saa7134/saa7134-tvaudio.c
index c5d0b44..76b1640 100644
--- a/drivers/media/video/saa7134/saa7134-tvaudio.c
+++ b/drivers/media/video/saa7134/saa7134-tvaudio.c
@@ -159,7 +159,7 @@ static struct saa7134_tvaudio tvaudio[] = {
 		.mode          = TVAUDIO_FM_MONO,
-#define TVAUDIO (sizeof(tvaudio)/sizeof(struct saa7134_tvaudio))
+#define TVAUDIO ARRAY_SIZE(tvaudio)
BtrLinux
Privacy Overview
