V4L/DVB (7285): em28xx: Correct use of ! and &
In commit e6bafba5b4765a5a252f1b8d31cbf6d2459da337, a bug was fixed that
involved converting !x & y to !(x & y).  The code below shows the same
pattern, and thus should perhaps be fixed in the same way.
This is not tested and clearly changes the semantics, so it is only
something to consider.
The semantic patch that makes this change is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@@ expression E1,E2; @@
  !E1 & !E2
- !E1 & E2
+ !(E1 & E2)
Signed-off-by: Julia Lawall
Signed-off-by: Andrew Morton
Signed-off-by: Mauro Carvalho Chehab
 drivers/media/video/em28xx/em28xx-core.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/media/video/em28xx/em28xx-core.c b/drivers/media/video/em28xx/em28xx-core.c
index 7d1537c..8630ee0 100644
--- a/drivers/media/video/em28xx/em28xx-core.c
+++ b/drivers/media/video/em28xx/em28xx-core.c
@@ -267,7 +267,7 @@ static int em28xx_write_ac97(struct em28xx *dev, u8 reg, u8 *val)
 	for (i = 0; i < 10; i++) {
 		if ((ret = em28xx_read_reg(dev, AC97BUSY_REG)) < 0)
 			return ret;
-		if (!((u8) ret) & 0x01)
+		if (!(((u8)ret) & 0x01))
 			return 0;
 		msleep(5);
BtrLinux
Privacy Overview
