V4L/DVB (13610): uvc: Correct size given to memset
Memset should be given the size of the structure, not the size of the pointer.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
type T;
T *x;
expression E;
memset(x, E, sizeof(
 x))
Signed-off-by: Julia Lawall
Acked-by: Laurent Pinchart
Signed-off-by: Douglas Schilling Landgraf
Signed-off-by: Mauro Carvalho Chehab
 drivers/media/video/uvc/uvc_video.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/media/video/uvc/uvc_video.c b/drivers/media/video/uvc/uvc_video.c
index 05139a4..9a98028 100644
--- a/drivers/media/video/uvc/uvc_video.c
+++ b/drivers/media/video/uvc/uvc_video.c
@@ -145,7 +145,7 @@ static int uvc_get_video_ctrl(struct uvc_streaming *stream,
 		uvc_warn_once(stream->dev, UVC_WARN_MINMAX, "UVC non "
 			"compliance - GET_MIN/MAX(PROBE) incorrectly "
 			"supported. Enabling workaround.\n");
-		memset(ctrl, 0, sizeof ctrl);
+		memset(ctrl, 0, sizeof *ctrl);
 		ctrl->wCompQuality = le16_to_cpup((__le16 *)data);
 		ret = 0;
 		goto out;
BtrLinux
Privacy Overview
