V4L/DVB (12477): Use dst_type field instead of type_flags
It seems from other code that it is the dst_type field rather than the
type_flags field that contains values of the form DST_TYPE_IS...
The type_flags field contains values of the form DST_TYPE_HAS...
The semantic match that finds this problem is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@@ struct dst_state E; @@
*E.type_flags ==
  \( DST_TYPE_IS_SAT\|DST_TYPE_IS_TERR\|DST_TYPE_IS_CABLE\|DST_TYPE_IS_ATSC \)
*E.type_flags !=
Cc: Manu Abraham
Signed-off-by: Julia Lawall
Signed-off-by: Mauro Carvalho Chehab
 drivers/media/dvb/bt8xx/dst.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/media/dvb/bt8xx/dst.c b/drivers/media/dvb/bt8xx/dst.c
index fec1d77..91353a6 100644
--- a/drivers/media/dvb/bt8xx/dst.c
+++ b/drivers/media/dvb/bt8xx/dst.c
@@ -1059,7 +1059,7 @@ static int dst_get_tuner_info(struct dst_state *state)
 		dprintk(verbose, DST_ERROR, 1, "DST type has TS=188");
 	if (state->board_info[0] == 0xbc) {
-		if (state->type_flags != DST_TYPE_IS_ATSC)
+		if (state->dst_type != DST_TYPE_IS_ATSC)
 			state->type_flags |= DST_TYPE_HAS_TS188;
 		else
 			state->type_flags |= DST_TYPE_HAS_NEWTUNE_2;
BtrLinux
Privacy Overview
