drivers/media/video/ivtv/ivtv-ioctl.c | 5 +++--
drivers/media/video/ivtv/ivtv-irq.c | 2 +-
drivers/media/video/ivtv/ivtv-yuv.c | 3 ++-
drivers/media/video/ivtv/ivtvfb.c | 3 ++-
4 files changed, 8 insertions(+), 5 deletions(-)
diff --git a/drivers/media/video/ivtv/ivtv-ioctl.c b/drivers/media/video/ivtv/ivtv-ioctl.c
index 4a2d464..c342a9f 100644
--- a/drivers/media/video/ivtv/ivtv-ioctl.c
+++ b/drivers/media/video/ivtv/ivtv-ioctl.c
@@ -180,7 +180,7 @@ int ivtv_set_speed(struct ivtv *itv, int speed)
/* Wait for any DMA to finish */
prepare_to_wait(&itv->dma_waitq, &wait, TASK_INTERRUPTIBLE);
- while (itv->i_flags & IVTV_F_I_DMA) {
+ while (test_bit(IVTV_F_I_DMA, &itv->i_flags)) {
got_sig = signal_pending(current);
if (got_sig)
break;
@@ -1710,7 +1710,8 @@ static int ivtv_decoder_ioctls(struct file *filp, unsigned int cmd, void *arg)
we are waiting unlock first and later lock again. */
mutex_unlock(&itv->serialize_lock);
prepare_to_wait(&itv->event_waitq, &wait, TASK_INTERRUPTIBLE);
- if ((itv->i_flags & (IVTV_F_I_EV_DEC_STOPPED|IVTV_F_I_EV_VSYNC)) == 0)
+ if (!test_bit(IVTV_F_I_EV_DEC_STOPPED, &itv->i_flags) &&
+ !test_bit(IVTV_F_I_EV_VSYNC, &itv->i_flags))
schedule();
finish_wait(&itv->event_waitq, &wait);
mutex_lock(&itv->serialize_lock);
diff --git a/drivers/media/video/ivtv/ivtv-irq.c b/drivers/media/video/ivtv/ivtv-irq.c
index 01c14d2..cd9db0b 100644
--- a/drivers/media/video/ivtv/ivtv-irq.c
+++ b/drivers/media/video/ivtv/ivtv-irq.c
@@ -196,7 +196,7 @@ static int stream_enc_dma_append(struct ivtv_stream *s, u32 data[CX2341X_MBOX_MA
bytes_needed, s->name);
return -1;
- if (rc && !s->buffers_stolen && (s->s_flags & IVTV_F_S_APPL_IO)) {
+ if (rc && !s->buffers_stolen && test_bit(IVTV_F_S_APPL_IO, &s->s_flags)) {
IVTV_WARN("All %s stream buffers are full. Dropping data.\n", s->name);
IVTV_WARN("Cause: the application is not reading fast enough.\n");
diff --git a/drivers/media/video/ivtv/ivtv-yuv.c b/drivers/media/video/ivtv/ivtv-yuv.c
index 7912ed6..c087537 100644
--- a/drivers/media/video/ivtv/ivtv-yuv.c
+++ b/drivers/media/video/ivtv/ivtv-yuv.c
@@ -1063,7 +1063,8 @@ static int ivtv_yuv_udma_frame(struct ivtv *itv, struct ivtv_dma_frame *args)
/* if no UDMA is pending and no UDMA is in progress, then the DMA
is finished */
- while (itv->i_flags & (IVTV_F_I_UDMA_PENDING | IVTV_F_I_UDMA)) {
+ while (test_bit(IVTV_F_I_UDMA_PENDING, &itv->i_flags) ||
+ test_bit(IVTV_F_I_UDMA, &itv->i_flags)) {
/* don't interrupt if the DMA is in progress but break off
a still pending DMA. */
diff --git a/drivers/media/video/ivtv/ivtvfb.c b/drivers/media/video/ivtv/ivtvfb.c
index 66e6eb5..fa6bb85 100644
--- a/drivers/media/video/ivtv/ivtvfb.c
+++ b/drivers/media/video/ivtv/ivtvfb.c
@@ -298,7 +298,8 @@ static int ivtvfb_prep_dec_dma_to_device(struct ivtv *itv,
is finished */
got_sig = signal_pending(current); |
