V4L/DVB (10171): Use usb_set_intfdata
This code had calls to both usb_set_intfdata and dev_set_drvdata, doing the
same thing.
The semantic patch that lead to finding this problem is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@header@
@same depends on header@
position p;
usb_set_intfdata@p(...) { ... }
@depends on header@
position _p!=same.p;
identifier _f;
struct usb_interface *intf;
expression data;
_f@_p(...) { <+...
- dev_set_drvdata(&intf->dev, data);
+ usb_set_intfdata(intf, data);
Signed-off-by: Julia Lawall
Signed-off-by: Mauro Carvalho Chehab
 drivers/media/video/zr364xx.c | 1 -
 1 file changed, 1 deletion(-)
diff --git a/drivers/media/video/zr364xx.c b/drivers/media/video/zr364xx.c
index bf68ed9..9302356 100644
--- a/drivers/media/video/zr364xx.c
+++ b/drivers/media/video/zr364xx.c
@@ -893,7 +893,6 @@ static void zr364xx_disconnect(struct usb_interface *intf)
 	struct zr364xx_camera *cam = usb_get_intfdata(intf);
 	usb_set_intfdata(intf, NULL);
-	dev_set_drvdata(&intf->dev, NULL);
 	dev_info(&intf->dev, DRIVER_DESC " webcam unplugged\n");
 	if (cam->vdev)
 		video_unregister_device(cam->vdev);
BtrLinux
Privacy Overview
