usbnet: remove invalid check
Author: Andrzej Hajda <a.hajda@samsung.com>
skb->len is always non-negative.
The problem has been detected using proposed semantic patch
scripts/coccinelle/tests/unsigned_lesser_than_zero.cocci [1].
[1]: http://permalink.gmane.org/gmane.linux.kernel/2038576
Signed-off-by: Andrzej Hajda
Signed-off-by: David S. Miller
 drivers/net/usb/lan78xx.c  | 5 -----
 drivers/net/usb/smsc75xx.c | 5 -----
 drivers/net/usb/smsc95xx.c | 5 -----
 3 files changed, 15 deletions(-)
diff --git a/drivers/net/usb/lan78xx.c b/drivers/net/usb/lan78xx.c
index 6a70a72..d2a5f3f 100644
--- a/drivers/net/usb/lan78xx.c
+++ b/drivers/net/usb/lan78xx.c
@@ -2424,11 +2424,6 @@ static int lan78xx_rx(struct lan78xx_net *dev, struct sk_buff *skb)
 			skb_pull(skb, align_count);
-	if (unlikely(skb->len < 0)) {
-		netdev_warn(dev->net, "invalid rx length<0 %d", skb->len);
-		return 0;
 	return 1;
diff --git a/drivers/net/usb/smsc75xx.c b/drivers/net/usb/smsc75xx.c
index d9e7892..30033db 100644
--- a/drivers/net/usb/smsc75xx.c
+++ b/drivers/net/usb/smsc75xx.c
@@ -2185,11 +2185,6 @@ static int smsc75xx_rx_fixup(struct usbnet *dev, struct sk_buff *skb)
-		netdev_warn(dev->net, "invalid rx length<0 %d\n", skb->len);
-		return 0;
 	return 1;
diff --git a/drivers/net/usb/smsc95xx.c b/drivers/net/usb/smsc95xx.c
index 26423ad..66b3ab9 100644
--- a/drivers/net/usb/smsc95xx.c
+++ b/drivers/net/usb/smsc95xx.c
@@ -1815,11 +1815,6 @@ static int smsc95xx_rx_fixup(struct usbnet *dev, struct sk_buff *skb)
-		return 0;
 	return 1;
BtrLinux
Privacy Overview
