USB: uss720.c: move assignment out of if () block
Author: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
We should not be doing assignments within an if () block
so fix up the code to not do this.
change was created using Coccinelle.
CC: Andy Shevchenko
Reviewed-by: Felipe Balbi
 drivers/usb/misc/uss720.c | 6 ++++--
 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/drivers/usb/misc/uss720.c b/drivers/usb/misc/uss720.c
index 588d62a..bbd029c 100644
--- a/drivers/usb/misc/uss720.c
+++ b/drivers/usb/misc/uss720.c
@@ -714,7 +714,8 @@ static int uss720_probe(struct usb_interface *intf,
 	 * Allocate parport interface
-	if (!(priv = kzalloc(sizeof(struct parport_uss720_private), GFP_KERNEL))) {
+	priv = kzalloc(sizeof(struct parport_uss720_private), GFP_KERNEL);
+	if (!priv) {
 		usb_put_dev(usbdev);
 		return -ENOMEM;
@@ -723,7 +724,8 @@ static int uss720_probe(struct usb_interface *intf,
 	kref_init(&priv->ref_count);
 	spin_lock_init(&priv->asynclock);
 	INIT_LIST_HEAD(&priv->asynclist);
-	if (!(pp = parport_register_port(0, PARPORT_IRQ_NONE, PARPORT_DMA_NONE, &parport_uss720_ops))) {
+	pp = parport_register_port(0, PARPORT_IRQ_NONE, PARPORT_DMA_NONE, &parport_uss720_ops);
+	if (!pp) {
 		printk(KERN_WARNING "uss720: could not register parport\n");
 		goto probe_abort;
BtrLinux
Privacy Overview
