USB: speedtch.c: move assignment out of if () block
Author: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
We should not be doing assignments within an if () block
so fix up the code to not do this.
change was created using Coccinelle.
CC: Duncan Sands
Reviewed-by: Felipe Balbi
 drivers/usb/atm/speedtch.c | 18 ++++++++++++------
 1 file changed, 12 insertions(+), 6 deletions(-)
diff --git a/drivers/usb/atm/speedtch.c b/drivers/usb/atm/speedtch.c
index 0dc8c06..0270d13 100644
--- a/drivers/usb/atm/speedtch.c
+++ b/drivers/usb/atm/speedtch.c
@@ -255,7 +255,8 @@ static int speedtch_upload_firmware(struct speedtch_instance_data *instance,
 	usb_dbg(usbatm, "%s entered\n", __func__);
-	if (!(buffer = (unsigned char *)__get_free_page(GFP_KERNEL))) {
+	buffer = (unsigned char *)__get_free_page(GFP_KERNEL);
+	if (!buffer) {
 		ret = -ENOMEM;
 		usb_dbg(usbatm, "%s: no memory for buffer!\n", __func__);
 		goto out;
@@ -638,7 +639,8 @@ static void speedtch_handle_int(struct urb *int_urb)
 		goto fail;
-	if ((int_urb = instance->int_urb)) {
+	int_urb = instance->int_urb;
+	if (int_urb) {
 		ret = usb_submit_urb(int_urb, GFP_ATOMIC);
 		schedule_work(&instance->status_check_work);
 		if (ret < 0) {
@@ -650,7 +652,8 @@ static void speedtch_handle_int(struct urb *int_urb)
 	return;
 fail:
+	if (int_urb)
 		mod_timer(&instance->resubmit_timer, jiffies + msecs_to_jiffies(RESUBMIT_DELAY));
@@ -759,11 +762,13 @@ static void speedtch_release_interfaces(struct usb_device *usb_dev,
 	struct usb_interface *cur_intf;
 	int i;
-	for (i = 0; i < num_interfaces; i++)
-		if ((cur_intf = usb_ifnum_to_if(usb_dev, i))) {
+	for (i = 0; i < num_interfaces; i++) {
+		cur_intf = usb_ifnum_to_if(usb_dev, i);
+		if (cur_intf) {
 			usb_set_intfdata(cur_intf, NULL);
 			usb_driver_release_interface(&speedtch_usb_driver, cur_intf);
 static int speedtch_bind(struct usbatm_data *usbatm,
@@ -787,7 +792,8 @@ static int speedtch_bind(struct usbatm_data *usbatm,
 		return -ENODEV;
-	if (!(data_intf = usb_ifnum_to_if(usb_dev, INTERFACE_DATA))) {
+	data_intf = usb_ifnum_to_if(usb_dev, INTERFACE_DATA);
+	if (!data_intf) {
 		usb_err(usbatm, "%s: data interface not found!\n", __func__);
 		return -ENODEV;
