USB: serial: fix compare_const_fl.cocci warnings
Author: Mathieu OTHACEHE <m.othacehe@gmail.com>
Move constants to the right of binary operators where it increases
readability.
Generated by: scripts/coccinelle/misc/compare_const_fl.cocci
Signed-off-by: Mathieu OTHACEHE
[johan: drop some chunks and fix others, amend commit message ]
Signed-off-by: Johan Hovold
 drivers/usb/serial/ch341.c      |  2 +-
 drivers/usb/serial/ftdi_sio.c   | 10 ++++-----
 drivers/usb/serial/ftdi_sio.h   |  8 +++----
 drivers/usb/serial/garmin_gps.c | 48 ++++++++++++++++++++---------------------
 4 files changed, 34 insertions(+), 34 deletions(-)
diff --git a/drivers/usb/serial/ch341.c b/drivers/usb/serial/ch341.c
index c73808f..f139488 100644
--- a/drivers/usb/serial/ch341.c
+++ b/drivers/usb/serial/ch341.c
@@ -370,7 +370,7 @@ static void ch341_set_termios(struct tty_struct *tty,
 static void ch341_break_ctl(struct tty_struct *tty, int break_state)
 	const uint16_t ch341_break_reg =
-		CH341_REG_BREAK1 | ((uint16_t) CH341_REG_BREAK2 << 8);
+			((uint16_t) CH341_REG_BREAK2 << 8) | CH341_REG_BREAK1;
 	struct usb_serial_port *port = tty->driver_data;
 	int r;
 	uint16_t reg_contents;
diff --git a/drivers/usb/serial/ftdi_sio.c b/drivers/usb/serial/ftdi_sio.c
index 8c660ae..427ae43 100644
--- a/drivers/usb/serial/ftdi_sio.c
+++ b/drivers/usb/serial/ftdi_sio.c
@@ -1320,11 +1320,11 @@ static __u32 get_ftdi_divisor(struct tty_struct *tty,
 		if (baud <= 3000000) {
 			__u16 product_id = le16_to_cpu(
 				port->serial->dev->descriptor.idProduct);
-			if (((FTDI_NDI_HUC_PID == product_id) ||
-			     (FTDI_NDI_SPECTRA_SCU_PID == product_id) ||
-			     (FTDI_NDI_FUTURE_2_PID == product_id) ||
-			     (FTDI_NDI_FUTURE_3_PID == product_id) ||
-			     (FTDI_NDI_AURORA_SCU_PID == product_id)) &&
+			if (((product_id == FTDI_NDI_HUC_PID)		||
+			     (product_id == FTDI_NDI_SPECTRA_SCU_PID)	||
+			     (product_id == FTDI_NDI_FUTURE_2_PID)	||
+			     (product_id == FTDI_NDI_FUTURE_3_PID)	||
+			     (product_id == FTDI_NDI_AURORA_SCU_PID))	&&
 			    (baud == 19200)) {
 				baud = 1200000;
diff --git a/drivers/usb/serial/ftdi_sio.h b/drivers/usb/serial/ftdi_sio.h
index ed58c6f..bbcc13df 100644
--- a/drivers/usb/serial/ftdi_sio.h
+++ b/drivers/usb/serial/ftdi_sio.h
@@ -239,11 +239,11 @@ enum ftdi_sio_baudrate {
 #define FTDI_SIO_SET_DTR_MASK 0x1
-#define FTDI_SIO_SET_DTR_HIGH (1 | (FTDI_SIO_SET_DTR_MASK  << 8))
-#define FTDI_SIO_SET_DTR_LOW  (0 | (FTDI_SIO_SET_DTR_MASK  << 8))
+#define FTDI_SIO_SET_DTR_HIGH ((FTDI_SIO_SET_DTR_MASK  << 8) | 1)
+#define FTDI_SIO_SET_DTR_LOW  ((FTDI_SIO_SET_DTR_MASK  << 8) | 0)
 #define FTDI_SIO_SET_RTS_MASK 0x2
-#define FTDI_SIO_SET_RTS_HIGH (2 | (FTDI_SIO_SET_RTS_MASK << 8))
-#define FTDI_SIO_SET_RTS_LOW (0 | (FTDI_SIO_SET_RTS_MASK << 8))
+#define FTDI_SIO_SET_RTS_HIGH ((FTDI_SIO_SET_RTS_MASK << 8) | 2)
+#define FTDI_SIO_SET_RTS_LOW  ((FTDI_SIO_SET_RTS_MASK << 8) | 0)
  * ControlValue
diff --git a/drivers/usb/serial/garmin_gps.c b/drivers/usb/serial/garmin_gps.c
index db591d1..9d4170c 100644
--- a/drivers/usb/serial/garmin_gps.c
+++ b/drivers/usb/serial/garmin_gps.c
@@ -237,10 +237,10 @@ static inline int getDataLength(const __u8 *usbPacket)
 static inline int isAbortTrfCmnd(const unsigned char *buf)
-	if (0 == memcmp(buf, GARMIN_STOP_TRANSFER_REQ,
-					sizeof(GARMIN_STOP_TRANSFER_REQ)) ||
-	    0 == memcmp(buf, GARMIN_STOP_TRANSFER_REQ_V2,
-					sizeof(GARMIN_STOP_TRANSFER_REQ_V2)))
+	if (memcmp(buf, GARMIN_STOP_TRANSFER_REQ,
+			sizeof(GARMIN_STOP_TRANSFER_REQ)) == 0 ||
+	    memcmp(buf, GARMIN_STOP_TRANSFER_REQ_V2,
+			sizeof(GARMIN_STOP_TRANSFER_REQ_V2)) == 0)
 		return 1;
 	else
 		return 0;
@@ -350,7 +350,7 @@ static int gsp_send_ack(struct garmin_data *garmin_data_p, __u8 pkt_id)
 	unsigned  l = 0;
 	dev_dbg(&garmin_data_p->port->dev, "%s - pkt-id: 0x%X.\n", __func__,
-		0xFF & pkt_id);
+			pkt_id);
 	*ptr++ = DLE;
 	*ptr++ = ACK;
@@ -366,7 +366,7 @@ static int gsp_send_ack(struct garmin_data *garmin_data_p, __u8 pkt_id)
 		*ptr++ = DLE;
 	*ptr++ = 0;
-	*ptr++ = 0xFF & (-cksum);
+	*ptr++ = (-cksum) & 0xFF;
 	*ptr++ = DLE;
 	*ptr++ = ETX;
@@ -423,9 +423,9 @@ static int gsp_rec_packet(struct garmin_data *garmin_data_p, int count)
 		n++;
-	if ((0xff & (cksum + *recpkt)) != 0) {
+	if (((cksum + *recpkt) & 0xff) != 0) {
 		dev_dbg(dev, "%s - invalid checksum, expected %02x, got %02x\n",
-			__func__, 0xff & -cksum, 0xff & *recpkt);
+			__func__, -cksum & 0xff, *recpkt);
 		return -EINVPKT;
@@ -528,7 +528,7 @@ static int gsp_receive(struct garmin_data *garmin_data_p,
 					dev_dbg(dev, "NAK packet complete.\n");
 				} else {
 					dev_dbg(dev, "packet complete - id=0x%X.\n",
-						0xFF & data);
+							data);
 					gsp_rec_packet(garmin_data_p, size);
@@ -636,7 +636,7 @@ static int gsp_send(struct garmin_data *garmin_data_p,
 	garmin_data_p->outsize = 0;
-	if (GARMIN_LAYERID_APPL != getLayerId(garmin_data_p->outbuffer)) {
+	if (getLayerId(garmin_data_p->outbuffer) != GARMIN_LAYERID_APPL) {
 		dev_dbg(dev, "not an application packet (%d)\n",
 				getLayerId(garmin_data_p->outbuffer));
 		return -1;
@@ -688,7 +688,7 @@ static int gsp_send(struct garmin_data *garmin_data_p,
 			*dst++ = DLE;
-	cksum = 0xFF & -cksum;
+	cksum = -cksum & 0xFF;
 	*dst++ = cksum;
 	if (cksum == DLE)
 		*dst++ = DLE;
@@ -970,7 +970,7 @@ static void garmin_write_bulk_callback(struct urb *urb)
 		struct garmin_data *garmin_data_p =
 					usb_get_serial_port_data(port);
-		if (GARMIN_LAYERID_APPL == getLayerId(urb->transfer_buffer)) {
+		if (getLayerId(urb->transfer_buffer) == GARMIN_LAYERID_APPL) {
 			if (garmin_data_p->mode == MODE_GARMIN_SERIAL) {
 				gsp_send_ack(garmin_data_p,
@@ -1025,7 +1025,7 @@ static int garmin_write_bulk(struct usb_serial_port *port,
 				dismiss_ack ? NULL : port);
 	urb->transfer_flags |= URB_ZERO_PACKET;
-	if (GARMIN_LAYERID_APPL == getLayerId(buffer)) {
+	if (getLayerId(buffer) == GARMIN_LAYERID_APPL) {
 		spin_lock_irqsave(&garmin_data_p->lock, flags);
 		garmin_data_p->flags |= APP_REQ_SEEN;
@@ -1077,9 +1077,9 @@ static int garmin_write(struct tty_struct *tty, struct usb_serial_port *port,
 		pktsiz = getDataLength(garmin_data_p->privpkt);
 		pktid  = getPacketId(garmin_data_p->privpkt);
-		if (count == (GARMIN_PKTHDR_LENGTH+pktsiz)
-		    && GARMIN_LAYERID_PRIVATE ==
-				getLayerId(garmin_data_p->privpkt)) {
+		if (count == (GARMIN_PKTHDR_LENGTH + pktsiz) &&
+				getLayerId(garmin_data_p->privpkt) ==
+						GARMIN_LAYERID_PRIVATE) {
 			dev_dbg(dev, "%s - processing private request %d\n",
 				__func__, pktid);
@@ -1192,7 +1192,7 @@ static void garmin_read_bulk_callback(struct urb *urb)
 	garmin_read_process(garmin_data_p, data, urb->actual_length, 1);
 	if (urb->actual_length == 0 &&
-			0 != (garmin_data_p->flags & FLAGS_BULK_IN_RESTART)) {
+			(garmin_data_p->flags & FLAGS_BULK_IN_RESTART) != 0) {
 		garmin_data_p->flags &= ~FLAGS_BULK_IN_RESTART;
 		spin_unlock_irqrestore(&garmin_data_p->lock, flags);
@@ -1203,7 +1203,7 @@ static void garmin_read_bulk_callback(struct urb *urb)
 				__func__, retval);
 	} else if (urb->actual_length > 0) {
 		/* Continue trying to read until nothing more is received  */
-		if (0 == (garmin_data_p->flags & FLAGS_THROTTLED)) {
+		if ((garmin_data_p->flags & FLAGS_THROTTLED) == 0) {
 			retval = usb_submit_urb(port->read_urb, GFP_ATOMIC);
 			if (retval)
 				dev_err(&port->dev,
@@ -1249,12 +1249,12 @@ static void garmin_read_int_callback(struct urb *urb)
 			      urb->transfer_buffer);
 	if (urb->actual_length == sizeof(GARMIN_BULK_IN_AVAIL_REPLY) &&
-	    0 == memcmp(data, GARMIN_BULK_IN_AVAIL_REPLY,
-				sizeof(GARMIN_BULK_IN_AVAIL_REPLY))) {
+		memcmp(data, GARMIN_BULK_IN_AVAIL_REPLY,
+				sizeof(GARMIN_BULK_IN_AVAIL_REPLY)) == 0) {
 		dev_dbg(&port->dev, "%s - bulk data available.\n", __func__);
-		if (0 == (garmin_data_p->flags & FLAGS_BULK_IN_ACTIVE)) {
+		if ((garmin_data_p->flags & FLAGS_BULK_IN_ACTIVE) == 0) {
 			/* bulk data available */
@@ -1276,8 +1276,8 @@ static void garmin_read_int_callback(struct urb *urb)
 	} else if (urb->actual_length == (4+sizeof(GARMIN_START_SESSION_REPLY))
-			 && 0 == memcmp(data, GARMIN_START_SESSION_REPLY,
-					sizeof(GARMIN_START_SESSION_REPLY))) {
+			 && memcmp(data, GARMIN_START_SESSION_REPLY,
+				 sizeof(GARMIN_START_SESSION_REPLY)) == 0) {
 		garmin_data_p->flags |= FLAGS_SESSION_REPLY1_SEEN;
@@ -1356,7 +1356,7 @@ static void garmin_unthrottle(struct tty_struct *tty)
 	if (garmin_data_p->mode == MODE_NATIVE)
 		garmin_flush_queue(garmin_data_p);
-	if (0 != (garmin_data_p->flags & FLAGS_BULK_IN_ACTIVE)) {
+	if ((garmin_data_p->flags & FLAGS_BULK_IN_ACTIVE) != 0) {
 		status = usb_submit_urb(port->read_urb, GFP_KERNEL);
 		if (status)
 			dev_err(&port->dev,
BtrLinux
Privacy Overview
