USB: serial: Eliminate useless code
The variables priv and portdata are initialized twice to the same (side
effect-free) expressions.  Drop one initialization in each case.
A simplified version of the semantic match that finds this problem is:
(http://coccinelle.lip6.fr/)
@forall@
idexpression *x;
identifier f!=ERR_PTR;
x = f(...)
... when != x
x = f(...,<+...x...+>,...)
* x = f(...)
Signed-off-by: Julia Lawall
 drivers/usb/serial/cypress_m8.c | 1 -
 drivers/usb/serial/sierra.c     | 2 +-
 2 files changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/usb/serial/cypress_m8.c b/drivers/usb/serial/cypress_m8.c
index eee8726..c349f79 100644
--- a/drivers/usb/serial/cypress_m8.c
+++ b/drivers/usb/serial/cypress_m8.c
@@ -691,7 +691,6 @@ static void cypress_dtr_rts(struct usb_serial_port *port, int on)
 	struct cypress_private *priv = usb_get_serial_port_data(port);
 	/* drop dtr and rts */
-	priv = usb_get_serial_port_data(port);
 	spin_lock_irq(&priv->lock);
 	if (on == 0)
 		priv->line_control = 0;
diff --git a/drivers/usb/serial/sierra.c b/drivers/usb/serial/sierra.c
index ea27f7d..bb0d56c 100644
--- a/drivers/usb/serial/sierra.c
+++ b/drivers/usb/serial/sierra.c
@@ -477,7 +477,7 @@ static void sierra_outdat_callback(struct urb *urb)
 static int sierra_write(struct tty_struct *tty, struct usb_serial_port *port,
 					const unsigned char *buf, int count)
-	struct sierra_port_private *portdata = usb_get_serial_port_data(port);
+	struct sierra_port_private *portdata;
 	struct sierra_intf_private *intfdata;
 	struct usb_serial *serial = port->serial;
 	unsigned long flags;
BtrLinux
Privacy Overview
