USB: Remove redundant test in pxa27x_udc and ftdi_sio
priv is checked not to be NULL near the beginning of the function and not
changed subsequently, making the test redundant.
A simplified version of the semantic patch that makes this change is as
follows: (http://www.emn.fr/x-info/coccinelle/)
@r exists@
local idexpression x;
expression E;
position p1,p2;
if (x@p1 == NULL || ...) { ... when forall
   return ...; }
... when != \(x=E\|x--\|x++\|--x\|++x\|x-=E\|x+=E\|x|=E\|x&=E\|&x\)
x@p2 == NULL
x@p2 != NULL
// another path to the test that is not through p1?
@s exists@
local idexpression r.x;
position r.p1,r.p2;
... when != x@p1
x@p2 == NULL
x@p2 != NULL
@fix depends on !s@
position r.p1,r.p2;
expression x,E;
statement S1,S2;
- if ((x@p2 != NULL) || ...)
  S1
- if ((x@p2 == NULL) && ...) S1
- BUG_ON(x@p2 == NULL);
Signed-off-by: Julia Lawall
 drivers/usb/gadget/pxa27x_udc.c |  2 +-
 drivers/usb/serial/ftdi_sio.c   | 16 +++++++---------
 2 files changed, 8 insertions(+), 10 deletions(-)
diff --git a/drivers/usb/gadget/pxa27x_udc.c b/drivers/usb/gadget/pxa27x_udc.c
index e50419d..91ba1e9 100644
--- a/drivers/usb/gadget/pxa27x_udc.c
+++ b/drivers/usb/gadget/pxa27x_udc.c
@@ -279,7 +279,7 @@ static void pxa_init_debugfs(struct pxa_udc *udc)
 		goto err_queues;
 	eps = debugfs_create_file("epstate", 0400, root, udc,
 			&eps_dbg_fops);
-	if (!queues)
+	if (!eps)
 		goto err_eps;
 	udc->debugfs_root = root;
diff --git a/drivers/usb/serial/ftdi_sio.c b/drivers/usb/serial/ftdi_sio.c
index ae84c32..d889216 100644
--- a/drivers/usb/serial/ftdi_sio.c
+++ b/drivers/usb/serial/ftdi_sio.c
@@ -1938,15 +1938,13 @@ static void ftdi_process_read(struct work_struct *work)
 		/* Compare new line status to the old one, signal if different/
 		   N.B. packet may be processed more than once, but differences
 		   are only processed once.  */
-		if (priv != NULL) {
-			char new_status = data[packet_offset + 0] &
-							FTDI_STATUS_B0_MASK;
-			if (new_status != priv->prev_status) {
-				priv->diff_status |=
-					new_status ^ priv->prev_status;
-				wake_up_interruptible(&priv->delta_msr_wait);
-				priv->prev_status = new_status;
+		char new_status = data[packet_offset + 0] &
+						FTDI_STATUS_B0_MASK;
+		if (new_status != priv->prev_status) {
+			priv->diff_status |=
+				new_status ^ priv->prev_status;
+			wake_up_interruptible(&priv->delta_msr_wait);
+			priv->prev_status = new_status;
 		length = min(PKTSZ, urb->actual_length-packet_offset)-2; |
 		goto err_queues;
 			&eps_dbg_fops);
-	if (!queues)
+	if (!eps)
 		goto err_eps;
