USB: PCI-quirks: Deletion of unnecessary checks before the function call “pci_dev_put”
Author: Markus Elfring <elfring@users.sourceforge.net>
The pci_dev_put() function tests whether its argument is NULL and then
returns immediately. Thus the test around the call is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
 drivers/usb/host/pci-quirks.c | 12 ++++--------
 1 file changed, 4 insertions(+), 8 deletions(-)
diff --git a/drivers/usb/host/pci-quirks.c b/drivers/usb/host/pci-quirks.c
index 2f3aceb..dd483c1 100644
--- a/drivers/usb/host/pci-quirks.c
+++ b/drivers/usb/host/pci-quirks.c
@@ -233,10 +233,8 @@ commit:
 		spin_unlock_irqrestore(&amd_lock, flags);
-		if (info.nb_dev)
-			pci_dev_put(info.nb_dev);
-		if (info.smbus_dev)
-			pci_dev_put(info.smbus_dev);
+		pci_dev_put(info.nb_dev);
+		pci_dev_put(info.smbus_dev);
 	} else {
 		/* no race - commit the result */
@@ -447,10 +445,8 @@ void usb_amd_dev_put(void)
-	if (nb)
-		pci_dev_put(nb);
-	if (smbus)
-		pci_dev_put(smbus);
+	pci_dev_put(nb);
+	pci_dev_put(smbus);
 EXPORT_SYMBOL_GPL(usb_amd_dev_put);
