usb: oxu210hp-hcd: Use setup_timer
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Convert a call to init_timer and accompanying intializations of
the timer's data and function fields to a call to setup_timer.
A simplified version of the semantic match that fixes this problem is as
follows: (http://coccinelle.lip6.fr/)
expression t,f,d;
-init_timer(&t);
+setup_timer(&t,f,d);
-t.function = f;
-t.data = d;
Signed-off-by: Julia Lawall
 drivers/usb/host/oxu210hp-hcd.c | 4 +---
 1 file changed, 1 insertion(+), 3 deletions(-)
diff --git a/drivers/usb/host/oxu210hp-hcd.c b/drivers/usb/host/oxu210hp-hcd.c
index 036924e..ea0ecbc 100644
--- a/drivers/usb/host/oxu210hp-hcd.c
+++ b/drivers/usb/host/oxu210hp-hcd.c
@@ -2598,9 +2598,7 @@ static int oxu_hcd_init(struct usb_hcd *hcd)
 	spin_lock_init(&oxu->lock);
-	init_timer(&oxu->watchdog);
-	oxu->watchdog.function = oxu_watchdog;
-	oxu->watchdog.data = (unsigned long) oxu;
+	setup_timer(&oxu->watchdog, oxu_watchdog, (unsigned long)oxu);
 	 * hw default: 1K periodic list heads, one per frame.
BtrLinux
Privacy Overview
