USB: ohci-hcd.c: move assignment out of if () block
Author: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
We should not be doing assignments within an if () block
so fix up the code to not do this.
change was created using Coccinelle.
Acked-by: Alan Stern
Reviewed-by: Felipe Balbi
 drivers/usb/host/ohci-hcd.c | 3 ++-
 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/usb/host/ohci-hcd.c b/drivers/usb/host/ohci-hcd.c
index 1dab9df..760cb57 100644
--- a/drivers/usb/host/ohci-hcd.c
+++ b/drivers/usb/host/ohci-hcd.c
@@ -155,7 +155,8 @@ static int ohci_urb_enqueue (
 	int		retval = 0;
 	/* every endpoint has a ed, locate and maybe (re)initialize it */
-	if (! (ed = ed_get (ohci, urb->ep, urb->dev, pipe, urb->interval)))
+	ed = ed_get(ohci, urb->ep, urb->dev, pipe, urb->interval);
+	if (! ed)
 		return -ENOMEM;
 	/* for the private part of the URB we need the number of TDs (size) */
