USB: musb uses endpoint functions
This set of patches introduces calls to the following set of functions:
usb_endpoint_dir_in(epd)
usb_endpoint_dir_out(epd)
usb_endpoint_is_bulk_in(epd)
usb_endpoint_is_bulk_out(epd)
usb_endpoint_is_int_in(epd)
usb_endpoint_is_int_out(epd)
usb_endpoint_num(epd)
usb_endpoint_type(epd)
usb_endpoint_xfer_bulk(epd)
usb_endpoint_xfer_control(epd)
usb_endpoint_xfer_int(epd)
usb_endpoint_xfer_isoc(epd)
In some cases, introducing one of these functions is not possible, and it
just replaces an explicit integer value by one of the following constants:
USB_ENDPOINT_XFER_BULK
USB_ENDPOINT_XFER_CONTROL
USB_ENDPOINT_XFER_INT
USB_ENDPOINT_XFER_ISOC
An extract of the semantic patch that makes these changes is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@r1@ struct usb_endpoint_descriptor *epd; @@
- ((epd->bmAttributes & \(USB_ENDPOINT_XFERTYPE_MASK\|3\)) ==
- \(USB_ENDPOINT_XFER_CONTROL\|0\))
+ usb_endpoint_xfer_control(epd)
@r5@ struct usb_endpoint_descriptor *epd; @@
- ((epd->bEndpointAddress & \(USB_ENDPOINT_DIR_MASK\|0x80\)) ==
-  \(USB_DIR_IN\|0x80\))
+ usb_endpoint_dir_in(epd)
@inc@
#include
@depends on !inc && (r1||r5)@
+ #include
  #include
Signed-off-by: Julia Lawall
Acked-by: Felipe Balbi
Signed-off-by: David Brownell
 drivers/usb/musb/musb_gadget.c | 6 +++---
 drivers/usb/musb/musb_host.c   | 4 ++--
 2 files changed, 5 insertions(+), 5 deletions(-)
diff --git a/drivers/usb/musb/musb_gadget.c b/drivers/usb/musb/musb_gadget.c
index 6197dae..4ea3053 100644
--- a/drivers/usb/musb/musb_gadget.c
+++ b/drivers/usb/musb/musb_gadget.c
@@ -874,10 +874,10 @@ static int musb_gadget_enable(struct usb_ep *ep,
 		status = -EBUSY;
 		goto fail;
-	musb_ep->type = desc->bmAttributes & USB_ENDPOINT_XFERTYPE_MASK;
+	musb_ep->type = usb_endpoint_type(desc);
 	/* check direction and (later) maxpacket size against endpoint */
-	if ((desc->bEndpointAddress & USB_ENDPOINT_NUMBER_MASK) != epnum)
+	if (usb_endpoint_num(desc) != epnum)
 		goto fail;
 	/* REVISIT this rules out high bandwidth periodic transfers */
@@ -890,7 +890,7 @@ static int musb_gadget_enable(struct usb_ep *ep,
 	 * packet size (or fail), set the mode, clear the fifo
 	musb_ep_select(mbase, epnum);
-	if (desc->bEndpointAddress & USB_DIR_IN) {
+	if (usb_endpoint_dir_in(desc)) {
 		u16 int_txe = musb_readw(mbase, MUSB_INTRTXE);
 		if (hw_ep->is_shared_fifo)
diff --git a/drivers/usb/musb/musb_host.c b/drivers/usb/musb/musb_host.c
index 99fa612..a035cec 100644
--- a/drivers/usb/musb/musb_host.c
+++ b/drivers/usb/musb/musb_host.c
@@ -1847,8 +1847,8 @@ static int musb_urb_enqueue(
 		goto done;
-	qh->epnum = epd->bEndpointAddress & USB_ENDPOINT_NUMBER_MASK;
-	qh->type = epd->bmAttributes & USB_ENDPOINT_XFERTYPE_MASK;
+	qh->epnum = usb_endpoint_num(epd);
+	qh->type = usb_endpoint_type(epd);
 	/* NOTE: urb->dev->devnum is wrong during SET_ADDRESS */
 	qh->addr_reg = (u8) usb_pipedevice(urb->pipe);
BtrLinux
Privacy Overview
