usb: musb: backfin: Introduce the use of the managed version of kzalloc
Author: Himangi Saraogi <himangi774@gmail.com>
This patch moves data allocated using kzalloc to managed data allocated
using devm_kzalloc and cleans now unnecessary kfrees in probe and remove
functions. Also, a label is done away with and err2 and err3 renamed.
The following Coccinelle semantic patch was used for making the change:
@platform@
identifier p, probefn, removefn;
struct platform_driver p = {
  .probe = probefn,
  .remove = removefn,
@prb@
identifier platform.probefn, pdev;
expression e, e1, e2;
probefn(struct platform_device *pdev, ...) {
- e = kzalloc(e1, e2)
+ e = devm_kzalloc(&pdev->dev, e1, e2)
?-kfree(e);
@rem depends on prb@
identifier platform.removefn;
expression e;
removefn(...) {
- kfree(e);
Signed-off-by: Himangi Saraogi
Acked-by: Julia Lawall
Signed-off-by: Felipe Balbi
 drivers/usb/musb/blackfin.c | 20 ++++++++------------
 1 file changed, 8 insertions(+), 12 deletions(-)
diff --git a/drivers/usb/musb/blackfin.c b/drivers/usb/musb/blackfin.c
index d40d5f0..ac4422b 100644
--- a/drivers/usb/musb/blackfin.c
+++ b/drivers/usb/musb/blackfin.c
@@ -455,7 +455,7 @@ static int bfin_probe(struct platform_device *pdev)
 	int				ret = -ENOMEM;
-	glue = kzalloc(sizeof(*glue), GFP_KERNEL);
+	glue = devm_kzalloc(&pdev->dev, sizeof(*glue), GFP_KERNEL);
 	if (!glue) {
 		dev_err(&pdev->dev, "failed to allocate glue context\n");
 		goto err0;
@@ -464,7 +464,7 @@ static int bfin_probe(struct platform_device *pdev)
 	musb = platform_device_alloc("musb-hdrc", PLATFORM_DEVID_AUTO);
 	if (!musb) {
 		dev_err(&pdev->dev, "failed to allocate musb device\n");
-		goto err1;
+		goto err0;
 	musb->dev.parent		= &pdev->dev;
@@ -478,7 +478,7 @@ static int bfin_probe(struct platform_device *pdev)
 	glue->phy = usb_phy_generic_register();
 	if (IS_ERR(glue->phy))
-		goto err2;
+		goto err1;
 	platform_set_drvdata(pdev, glue);
 	memset(musb_resources, 0x00, sizeof(*musb_resources) *
@@ -498,31 +498,28 @@ static int bfin_probe(struct platform_device *pdev)
 			ARRAY_SIZE(musb_resources));
 	if (ret) {
 		dev_err(&pdev->dev, "failed to add resources\n");
-		goto err3;
+		goto err2;
 	ret = platform_device_add_data(musb, pdata, sizeof(*pdata));
 	if (ret) {
 		dev_err(&pdev->dev, "failed to add platform_data\n");
-		goto err3;
+		goto err2;
 	ret = platform_device_add(musb);
 	if (ret) {
 		dev_err(&pdev->dev, "failed to register musb device\n");
-		goto err3;
+		goto err2;
 	return 0;
-err3:
-	usb_phy_generic_unregister(glue->phy);
 err2:
-	platform_device_put(musb);
+	usb_phy_generic_unregister(glue->phy);
 err1:
-	kfree(glue);
+	platform_device_put(musb);
 err0:
 	return ret;
@@ -534,7 +531,6 @@ static int bfin_remove(struct platform_device *pdev)
 	platform_device_unregister(glue->musb);
-	kfree(glue);
 	return 0;
BtrLinux
Privacy Overview
