USB: io_edgeport: Use kzalloc
Use kzalloc rather than the combination of kmalloc and memset.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
expression x,size,flags;
statement S;
-x = kmalloc(size,flags);
+x = kzalloc(size,flags);
 if (x == NULL) S
-memset(x, 0, size);
Signed-off-by: Julia Lawall
 drivers/usb/serial/io_edgeport.c | 3 +--
 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/usb/serial/io_edgeport.c b/drivers/usb/serial/io_edgeport.c
index 3ef8df0..76e6fb3 100644
--- a/drivers/usb/serial/io_edgeport.c
+++ b/drivers/usb/serial/io_edgeport.c
@@ -3020,7 +3020,7 @@ static int edge_startup(struct usb_serial *serial)
 	/* set up our port private structures */
 	for (i = 0; i < serial->num_ports; ++i) {
-		edge_port = kmalloc(sizeof(struct edgeport_port), GFP_KERNEL);
+		edge_port = kzalloc(sizeof(struct edgeport_port), GFP_KERNEL);
 		if (edge_port == NULL) {
 			dev_err(&serial->dev->dev, "%s - Out of memory\n",
 								   __func__);
@@ -3033,7 +3033,6 @@ static int edge_startup(struct usb_serial *serial)
 			kfree(edge_serial);
 			return -ENOMEM;
-		memset(edge_port, 0, sizeof(struct edgeport_port));
 		spin_lock_init(&edge_port->ep_lock);
 		edge_port->port = serial->port[i];
 		usb_set_serial_port_data(serial->port[i], edge_port);
