USB hub: make USB device id constant
Author: Németh Márton <nm127@freemail.hu>
The id_table field of the struct usb_device_id is constant in
so it is worth to make the initialization data also constant.
The semantic match that finds this kind of pattern is as follows:
(http://coccinelle.lip6.fr/)
@r@
disable decl_init,const_decl_init;
identifier I1, I2, x;
struct I1 {
const struct I2 *x;
@s@
identifier r.I1, y;
identifier r.x, E;
struct I1 y = {
.x = E,
@c@
identifier r.I2;
identifier s.E;
const struct I2 E[] = ... ;
@depends on !c@
identifier r.I2;
identifier s.E;
+ const
struct I2 E[] = ...;
Signed-off-by: Németh Márton
Cc: Julia Lawall
Cc: cocci@diku.dk
drivers/usb/core/hub.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/usb/core/hub.c b/drivers/usb/core/hub.c
index e198ff8..0940ccd 100644
--- a/drivers/usb/core/hub.c
+++ b/drivers/usb/core/hub.c
@@ -3432,7 +3432,7 @@ static int hub_thread(void *__unused)
return 0;
-static struct usb_device_id hub_id_table [] = {
+static const struct usb_device_id hub_id_table[] = {
{ .match_flags = USB_DEVICE_ID_MATCH_DEV_CLASS,
.bDeviceClass = USB_CLASS_HUB},
{ .match_flags = USB_DEVICE_ID_MATCH_INT_CLASS, |
return 0;
