USB: hcd.c: move assignment out of if () block
Author: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
We should not be doing assignments within an if () block
so fix up the code to not do this.
change was created using Coccinelle.
Acked-by: Alan Stern
CC: Dan Williams
CC: Antoine Tenart
CC: Petr Mladek
CC: Michal Sojka
CC: "Rafael J. Wysocki"
CC: Sergei Shtylyov
Reviewed-by: Felipe Balbi
drivers/usb/core/hcd.c | 3 ++-
1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/usb/core/hcd.c b/drivers/usb/core/hcd.c
index 45a915c..be5b207 100644
--- a/drivers/usb/core/hcd.c
+++ b/drivers/usb/core/hcd.c
@@ -2691,7 +2691,8 @@ int usb_add_hcd(struct usb_hcd *hcd,
if ((retval = usb_register_bus(&hcd->self)) < 0)
goto err_register_bus;
- if ((rhdev = usb_alloc_dev(NULL, &hcd->self, 0)) == NULL) {
+ rhdev = usb_alloc_dev(NULL, &hcd->self, 0);
+ if (rhdev == NULL) {
dev_err(hcd->self.controller, "unable to allocate root hub\n");
retval = -ENOMEM;
goto err_allocate_root_hub; |
retval = -ENOMEM;
