USB: gadget: Use kmemdup
Use kmemdup when some other buffer is immediately copied into the
allocated region.
A simplified version of the semantic patch that makes this change is as
follows: (http://coccinelle.lip6.fr/)
expression from,to,size,flag;
statement S;
-  to = \(kmalloc\|kzalloc\)(size,flag);
+  to = kmemdup(from,size,flag);
   if (to==NULL || ...) S
-  memcpy(to, from, size);
Signed-off-by: Julia Lawall
 drivers/usb/gadget/atmel_usba_udc.c | 3 +--
 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/usb/gadget/atmel_usba_udc.c b/drivers/usb/gadget/atmel_usba_udc.c
index 75a256f..d623c7b 100644
--- a/drivers/usb/gadget/atmel_usba_udc.c
+++ b/drivers/usb/gadget/atmel_usba_udc.c
@@ -48,10 +48,9 @@ static int queue_dbg_open(struct inode *inode, struct file *file)
 	spin_lock_irq(&ep->udc->lock);
 	list_for_each_entry(req, &ep->queue, queue) {
-		req_copy = kmalloc(sizeof(*req_copy), GFP_ATOMIC);
+		req_copy = kmemdup(req, sizeof(*req_copy), GFP_ATOMIC);
 		if (!req_copy)
 			goto fail;
-		memcpy(req_copy, req, sizeof(*req_copy));
 		list_add_tail(&req_copy->queue, queue_data);
 	spin_unlock_irq(&ep->udc->lock);
