USB: gadget: Use ERR_PTR/IS_ERR
Use ERR_PTR and IS_ERR rather than mixing integers and pointers.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
expression *E;
* E < 0
Signed-off-by: Julia Lawall
Acked-by: David Brownell
drivers/usb/gadget/f_audio.c | 8 +++++---
1 file changed, 5 insertions(+), 3 deletions(-)
diff --git a/drivers/usb/gadget/f_audio.c b/drivers/usb/gadget/f_audio.c
index c43c89f..0f2eee1 100644
--- a/drivers/usb/gadget/f_audio.c
+++ b/drivers/usb/gadget/f_audio.c
@@ -252,12 +252,12 @@ static struct f_audio_buf *f_audio_buffer_alloc(int buf_size)
copy_buf = kzalloc(sizeof *copy_buf, GFP_ATOMIC);
if (!copy_buf)
- return (struct f_audio_buf *)-ENOMEM;
+ return ERR_PTR(-ENOMEM);
copy_buf->buf = kzalloc(buf_size, GFP_ATOMIC);
if (!copy_buf->buf) {
kfree(copy_buf);
return copy_buf;
@@ -332,7 +332,7 @@ static int f_audio_out_ep_complete(struct usb_ep *ep, struct usb_request *req)
list_add_tail(©_buf->list, &audio->play_queue);
schedule_work(&audio->playback_work);
copy_buf = f_audio_buffer_alloc(audio_buf_size);
- if (copy_buf < 0)
+ if (IS_ERR(copy_buf))
return -ENOMEM;
@@ -576,6 +576,8 @@ static int f_audio_set_alt(struct usb_function *f, unsigned intf, unsigned alt)
usb_ep_enable(out_ep, audio->out_desc);
out_ep->driver_data = audio;
audio->copy_buf = f_audio_buffer_alloc(audio_buf_size);
+ if (IS_ERR(audio->copy_buf))
+ return -ENOMEM;
* allocate a bunch of read buffers |
if (!copy_buf)
kfree(copy_buf);
return copy_buf;
- if (copy_buf < 0)
return -ENOMEM;
+ return -ENOMEM;
