usb: gadget: udc: use USB API functions rather than constants
Author: Himangi Saraogi <himangi774@gmail.com>
This patch introduces the use of the functions usb_endpoint_type and
usb_endpoint_num.
The Coccinelle semantic patch that makes these changes is as follows:
@@ struct usb_endpoint_descriptor *epd; @@
- (epd->bEndpointAddress & \(USB_ENDPOINT_NUMBER_MASK\|0x0f\))
+ usb_endpoint_num(epd)
- (epd->bmAttributes & \(USB_ENDPOINT_XFERTYPE_MASK\|3\))
+ usb_endpoint_type(epd)
Signed-off-by: Himangi Saraogi
Acked-by: Julia Lawall
Signed-off-by: Felipe Balbi
 drivers/usb/gadget/udc/r8a66597-udc.c | 6 +++---
 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/usb/gadget/udc/r8a66597-udc.c b/drivers/usb/gadget/udc/r8a66597-udc.c
index 68a7d20..00f7345 100644
--- a/drivers/usb/gadget/udc/r8a66597-udc.c
+++ b/drivers/usb/gadget/udc/r8a66597-udc.c
@@ -430,7 +430,7 @@ static void r8a66597_ep_setting(struct r8a66597 *r8a66597,
 	ep->pipenum = pipenum;
 	ep->ep.maxpacket = usb_endpoint_maxp(desc);
 	r8a66597->pipenum2ep[pipenum] = ep;
-	r8a66597->epaddr2ep[desc->bEndpointAddress & USB_ENDPOINT_NUMBER_MASK]
+	r8a66597->epaddr2ep[usb_endpoint_num(desc)]
 		= ep;
 	INIT_LIST_HEAD(&ep->queue);
@@ -464,7 +464,7 @@ static int alloc_pipe_config(struct r8a66597_ep *ep,
 	if (ep->pipenum)	/* already allocated pipe  */
 		return 0;
-	switch (desc->bmAttributes & USB_ENDPOINT_XFERTYPE_MASK) {
+	switch (usb_endpoint_type(desc)) {
 	case USB_ENDPOINT_XFER_BULK:
 		if (r8a66597->bulk >= R8A66597_MAX_NUM_BULK) {
 			if (r8a66597->isochronous >= R8A66597_MAX_NUM_ISOC) {
@@ -509,7 +509,7 @@ static int alloc_pipe_config(struct r8a66597_ep *ep,
 	ep->type = info.type;
-	info.epnum = desc->bEndpointAddress & USB_ENDPOINT_NUMBER_MASK;
+	info.epnum = usb_endpoint_num(desc);
 	info.maxpacket = usb_endpoint_maxp(desc);
 	info.interval = desc->bInterval;
 	if (desc->bEndpointAddress & USB_ENDPOINT_DIR_MASK)
BtrLinux
Privacy Overview
