usb: gadget: s3c-hsotg.c: fix error return code
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Convert a 0 error return code to a negative one, as returned elsewhere in the
function.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
identifier ret;
expression e,e1,e2,e3,e4,x;
if (\(ret != 0\|ret < 0\) || ...) { ... return ...; }
ret = 0
... when != ret = e1
*x = \(kmalloc\|kzalloc\|kcalloc\|devm_kzalloc\|ioremap\|ioremap_nocache\|devm_ioremap\|devm_ioremap_nocache\)(...);
... when != x = e2
    when != ret = e3
*if (x == NULL || ...)
  ... when != ret = e4
*  return ret;
Signed-off-by: Julia Lawall
Signed-off-by: Felipe Balbi
 drivers/usb/gadget/s3c-hsotg.c | 3 +++
 1 file changed, 3 insertions(+)
diff --git a/drivers/usb/gadget/s3c-hsotg.c b/drivers/usb/gadget/s3c-hsotg.c
index b13e0bb..0bb617e 100644
--- a/drivers/usb/gadget/s3c-hsotg.c
+++ b/drivers/usb/gadget/s3c-hsotg.c
@@ -3599,6 +3599,7 @@ static int __devinit s3c_hsotg_probe(struct platform_device *pdev)
 	if (hsotg->num_of_eps == 0) {
 		dev_err(dev, "wrong number of EPs (zero)\n");
+		ret = -EINVAL;
 		goto err_supplies;
@@ -3606,6 +3607,7 @@ static int __devinit s3c_hsotg_probe(struct platform_device *pdev)
 		      GFP_KERNEL);
 	if (!eps) {
 		dev_err(dev, "cannot get memory\n");
+		ret = -ENOMEM;
 		goto err_supplies;
@@ -3622,6 +3624,7 @@ static int __devinit s3c_hsotg_probe(struct platform_device *pdev)
 						     GFP_KERNEL);
 	if (!hsotg->ctrl_req) {
 		dev_err(dev, "failed to allocate ctrl req\n");
+		ret = -ENOMEM;
 		goto err_ep_mem;
BtrLinux
Privacy Overview
