USB gadget: make Open Firmware device id constant
Author: Németh Márton <nm127@freemail.hu>
The match_table field of the struct of_device_id is constant in
so it is worth to make ace_of_match also constant.
The semantic match that finds this kind of pattern is as follows:
(http://coccinelle.lip6.fr/)
@r@
disable decl_init,const_decl_init;
identifier I1, I2, x;
	struct I1 {
	  const struct I2 *x;
@s@
identifier r.I1, y;
identifier r.x, E;
	struct I1 y = {
	  .x = E,
@c@
identifier r.I2;
identifier s.E;
	const struct I2 E[] = ... ;
@depends on !c@
identifier r.I2;
identifier s.E;
+	const
	struct I2 E[] = ...;
Signed-off-by: Németh Márton
Cc: Julia Lawall
Cc: cocci@diku.dk
 drivers/usb/gadget/fsl_qe_udc.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/usb/gadget/fsl_qe_udc.c b/drivers/usb/gadget/fsl_qe_udc.c
index 7881f12..3537d51 100644
--- a/drivers/usb/gadget/fsl_qe_udc.c
+++ b/drivers/usb/gadget/fsl_qe_udc.c
@@ -2749,7 +2749,7 @@ static int __devexit qe_udc_remove(struct of_device *ofdev)
-static struct of_device_id __devinitdata qe_udc_match[] = {
+static const struct of_device_id qe_udc_match[] __devinitconst = {
 		.compatible = "fsl,mpc8323-qe-usb",
 		.data = (void *)PORT_QE,
BtrLinux
Privacy Overview
