usb: gadget: fix error return code
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Convert a zero return value on error to a negative one, as returned
elsewhere in the function.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
identifier ret; expression e1,e2;
if (\(ret < 0\|ret != 0\))
 { ... return ret; }
ret = 0
... when != ret = e1
    when != &ret
*if(...)
  ... when != ret = e2
      when forall
 return ret;
Reviewed-by: Jeff Moyer
Signed-off-by: Julia Lawall
Signed-off-by: Felipe Balbi
 drivers/usb/gadget/udc/fusb300_udc.c | 8 ++++++--
 1 file changed, 6 insertions(+), 2 deletions(-)
diff --git a/drivers/usb/gadget/udc/fusb300_udc.c b/drivers/usb/gadget/udc/fusb300_udc.c
index d40255f..5c5d1ad 100644
--- a/drivers/usb/gadget/udc/fusb300_udc.c
+++ b/drivers/usb/gadget/udc/fusb300_udc.c
@@ -1398,13 +1398,17 @@ static int fusb300_probe(struct platform_device *pdev)
 	/* initialize udc */
 	fusb300 = kzalloc(sizeof(struct fusb300), GFP_KERNEL);
-	if (fusb300 == NULL)
+	if (fusb300 == NULL) {
+		ret = -ENOMEM;
 		goto clean_up;
 	for (i = 0; i < FUSB300_MAX_NUM_EP; i++) {
 		_ep[i] = kzalloc(sizeof(struct fusb300_ep), GFP_KERNEL);
-		if (_ep[i] == NULL)
+		if (_ep[i] == NULL) {
+			ret = -ENOMEM;
 			goto clean_up;
 		fusb300->ep[i] = _ep[i];
BtrLinux
Privacy Overview
