usb: gadget: fix error return code
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Set the return variable to an error code as done elsewhere in the function.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
if@p1 (\(ret < 0\|ret != 0\))
 { ... return ret; }
ret@p1 = 0
... when != ret = e1
    when != &ret
*if(...)
  ... when != ret = e2
      when forall
 return ret;
Signed-off-by: Julia Lawall
Signed-off-by: Felipe Balbi
 drivers/usb/gadget/printer.c | 1 +
 1 file changed, 1 insertion(+)
diff --git a/drivers/usb/gadget/printer.c b/drivers/usb/gadget/printer.c
index bf7a56b..92b55bd 100644
--- a/drivers/usb/gadget/printer.c
+++ b/drivers/usb/gadget/printer.c
@@ -1133,6 +1133,7 @@ static int __init printer_bind_config(struct usb_configuration *c)
 				  NULL, "g_printer");
 	if (IS_ERR(dev->pdev)) {
 		ERROR(dev, "Failed to create device: g_printer\n");
+		status = PTR_ERR(dev->pdev);
 		goto fail;
BtrLinux
Privacy Overview
