USB: fusbh200-hcd.c: move assignment out of if () block
Author: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
We should not be doing assignments within an if () block
so fix up the code to not do this.
change was created using Coccinelle.
CC: Sergei Shtylyov
Acked-by: Alan Stern
CC: Petr Mladek
CC: Randy Dunlap
CC: Masanari Iida
Reviewed-by: Felipe Balbi
 drivers/usb/host/fusbh200-hcd.c | 3 ++-
 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/usb/host/fusbh200-hcd.c b/drivers/usb/host/fusbh200-hcd.c
index 00e492e..1fd8718 100644
--- a/drivers/usb/host/fusbh200-hcd.c
+++ b/drivers/usb/host/fusbh200-hcd.c
@@ -499,7 +499,8 @@ static ssize_t fill_periodic_buffer(struct debug_buffer *buf)
 	unsigned		i;
 	__hc32			tag;
-	if (!(seen = kmalloc (DBG_SCHED_LIMIT * sizeof *seen, GFP_ATOMIC)))
+	seen = kmalloc(DBG_SCHED_LIMIT * sizeof *seen, GFP_ATOMIC);
+	if (!seen)
 		return 0;
 	seen_count = 0;
BtrLinux
Privacy Overview
