usb: ehci: ohci: fix bool assignments
Author: Geyslan G. Bem <geyslan@gmail.com>
When assigning bool use true instead of 1. If declaring it as static and
it's false there's no need to initialize it, since static variables are
zeroed by default.
Caught by coccinelle.
Signed-off-by: Geyslan G. Bem
 drivers/usb/host/ehci-hcd.c | 2 +-
 drivers/usb/host/ohci-hcd.c | 4 ++--
 drivers/usb/host/u132-hcd.c | 2 +-
 3 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/usb/host/ehci-hcd.c b/drivers/usb/host/ehci-hcd.c
index 48c92bf..14178bb 100644
--- a/drivers/usb/host/ehci-hcd.c
+++ b/drivers/usb/host/ehci-hcd.c
@@ -98,7 +98,7 @@ module_param (park, uint, S_IRUGO);
 MODULE_PARM_DESC (park, "park setting; 1-3 back-to-back async packets");
 /* for flakey hardware, ignore overcurrent indicators */
-static bool ignore_oc = 0;
+static bool ignore_oc;
 module_param (ignore_oc, bool, S_IRUGO);
 MODULE_PARM_DESC (ignore_oc, "ignore bogus hardware overcurrent indications");
diff --git a/drivers/usb/host/ohci-hcd.c b/drivers/usb/host/ohci-hcd.c
index 760cb57..04dcedf 100644
--- a/drivers/usb/host/ohci-hcd.c
+++ b/drivers/usb/host/ohci-hcd.c
@@ -99,13 +99,13 @@ static void io_watchdog_func(unsigned long _ohci);
 /* Some boards misreport power switching/overcurrent */
-static bool distrust_firmware = 1;
+static bool distrust_firmware = true;
 module_param (distrust_firmware, bool, 0);
 MODULE_PARM_DESC (distrust_firmware,
 	"true to distrust firmware power/overcurrent setup");
 /* Some boards leave IR set wrongly, since they fail BIOS/SMM handshakes */
-static bool no_handshake = 0;
+static bool no_handshake;
 module_param (no_handshake, bool, 0);
 MODULE_PARM_DESC (no_handshake, "true (not default) disables BIOS handshake");
diff --git a/drivers/usb/host/u132-hcd.c b/drivers/usb/host/u132-hcd.c
index 692ccc6..05c85c7 100644
--- a/drivers/usb/host/u132-hcd.c
+++ b/drivers/usb/host/u132-hcd.c
@@ -73,7 +73,7 @@ MODULE_LICENSE("GPL");
 #define INT_MODULE_PARM(n, v) static int n = v;module_param(n, int, 0444)
 INT_MODULE_PARM(testing, 0);
 /* Some boards misreport power switching/overcurrent*/
 module_param(distrust_firmware, bool, 0);
 MODULE_PARM_DESC(distrust_firmware, "true to distrust firmware power/overcurren"
 	"t setup");
BtrLinux
Privacy Overview
