usb: dwc3: return error code from the most recent call
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Copy-paste error from the previous block of error handling code.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
expression e,e1;
if (IS_ERR(e)) {
  ret = PTR_ERR(e);
*  ret = PTR_ERR(e1);
  return ret;
Signed-off-by: Julia Lawall
Signed-off-by: Felipe Balbi
 drivers/usb/dwc3/dwc3-st.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/usb/dwc3/dwc3-st.c b/drivers/usb/dwc3/dwc3-st.c
index c7602b5..4a1a543 100644
--- a/drivers/usb/dwc3/dwc3-st.c
+++ b/drivers/usb/dwc3/dwc3-st.c
@@ -243,7 +243,7 @@ static int st_dwc3_probe(struct platform_device *pdev)
 	dwc3_data->rstc_rst = devm_reset_control_get(dev, "softreset");
 	if (IS_ERR(dwc3_data->rstc_rst)) {
 		dev_err(&pdev->dev, "could not get reset controller\n");
-		ret = PTR_ERR(dwc3_data->rstc_pwrdn);
+		ret = PTR_ERR(dwc3_data->rstc_rst);
 		goto undo_powerdown;
BtrLinux
Privacy Overview
