USB: cp210x: remove useless set memory to zero use memset()
Author: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
The memory return by kzalloc() or kmem_cache_zalloc() has already
be set to zero, so remove useless memset(0).
spatch with a semantic match is used to found this problem.
(http://coccinelle.lip6.fr/)
Signed-off-by: Wei Yongjun
 drivers/usb/serial/cp210x.c | 1 -
 1 file changed, 1 deletion(-)
diff --git a/drivers/usb/serial/cp210x.c b/drivers/usb/serial/cp210x.c
index 1e71079..3f86cf3 100644
--- a/drivers/usb/serial/cp210x.c
+++ b/drivers/usb/serial/cp210x.c
@@ -865,7 +865,6 @@ static int cp210x_startup(struct usb_serial *serial)
 		if (!port_priv)
 			return -ENOMEM;
-		memset(port_priv, 0x00, sizeof(*port_priv));
 		port_priv->bInterfaceNumber =
 		    serial->interface->cur_altsetting->desc.bInterfaceNumber;
BtrLinux
Privacy Overview
