USB: constify usb_mon_operations structure
Author: Julia Lawall <julia.lawall@lip6.fr>
The usb_mon_operations structure is never modified, so declare it as const.
Done with the help of Coccinelle.
Signed-off-by: Julia Lawall
 drivers/usb/core/hcd.c     | 4 ++--
 drivers/usb/mon/mon_main.c | 2 +-
 include/linux/usb/hcd.h    | 4 ++--
 3 files changed, 5 insertions(+), 5 deletions(-)
diff --git a/drivers/usb/core/hcd.c b/drivers/usb/core/hcd.c
index 1c102d6..df0e3b9 100644
--- a/drivers/usb/core/hcd.c
+++ b/drivers/usb/core/hcd.c
@@ -3000,7 +3000,7 @@ EXPORT_SYMBOL_GPL(usb_hcd_platform_shutdown);
 #if defined(CONFIG_USB_MON) || defined(CONFIG_USB_MON_MODULE)
-struct usb_mon_operations *mon_ops;
+const struct usb_mon_operations *mon_ops;
  * The registration is unlocked.
@@ -3010,7 +3010,7 @@ struct usb_mon_operations *mon_ops;
  * symbols from usbcore, usbcore gets referenced and cannot be unloaded first.
-int usb_mon_register (struct usb_mon_operations *ops)
+int usb_mon_register(const struct usb_mon_operations *ops)
 	if (mon_ops)
diff --git a/drivers/usb/mon/mon_main.c b/drivers/usb/mon/mon_main.c
index f7c292f..fec3f11 100644
--- a/drivers/usb/mon/mon_main.c
+++ b/drivers/usb/mon/mon_main.c
@@ -241,7 +241,7 @@ static struct notifier_block mon_nb = {
  * Ops
-static struct usb_mon_operations mon_ops_0 = {
+static const struct usb_mon_operations mon_ops_0 = {
 	.urb_submit =	mon_submit,
 	.urb_submit_error = mon_submit_error,
 	.urb_complete =	mon_complete,
diff --git a/include/linux/usb/hcd.h b/include/linux/usb/hcd.h
index f89c24b..4dcf844 100644
--- a/include/linux/usb/hcd.h
+++ b/include/linux/usb/hcd.h
@@ -660,7 +660,7 @@ struct usb_mon_operations {
 	/* void (*urb_unlink)(struct usb_bus *bus, struct urb *urb); */
-extern struct usb_mon_operations *mon_ops;
+extern const struct usb_mon_operations *mon_ops;
 static inline void usbmon_urb_submit(struct usb_bus *bus, struct urb *urb)
@@ -682,7 +682,7 @@ static inline void usbmon_urb_complete(struct usb_bus *bus, struct urb *urb,
 		(*mon_ops->urb_complete)(bus, urb, status);
-int usb_mon_register(struct usb_mon_operations *ops);
+int usb_mon_register(const struct usb_mon_operations *ops);
 void usb_mon_deregister(void);
 #else
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
